Failure with a OP boolean subtraction
Matthew380
Member Posts: 50 ✭
So I am working on a project that auto lofts something to a shape or point without 2 surfaces, and when I did remove in the part studio, it would not merge with the boolean:
However, at the same time, there are no error messages and nothing that says anything is incorrect. I also tried to see if the IF statement just wasn't working, but I checked tha,t and it goes through the statement
What is happening?
Here is the document:
NeilCooke
Moderator, Onshape Employees Posts: 5,990
It is working, you just need to delete Part 2 - don't assume that subtraction removes the tools.
Senior Director, Technical Services, EMEA0
What error are you seeing?
The feature seems to be working just fine.
Learning to debug might help you solve your issues.
I wrote a blog with some tips and tricks on how to debug, functions like AddDebugEntities and debug arrows can be really helpful.
https://www.smartbenchsoftware.com/post/a-quick-guide-to-debugging-featurescript
I said no error was showing it just would never merge the parts together:
