Why do sketches not paste in to the same cords when copied?
Tony_C_Tony_C_ Member Posts: 277 PRO
Is there a reason when I copy a sketch to paste it into a new on that it doesn't retain its origin?
I always have to realign them.  Seems it would be much faster and easier if they dropped exactly where they were copied from.
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373
    @Tony_C_ Some additional notes from my digging:
    When you paste into a sketch that isn't active, the pasted entities get roughly centered on the origin. This is difficult to do that since the 2D reference to the origin doesn't carry through.
    When you paste into an active sketch, they go roughly where your mouse is.
    Twitter: @bradleysauln
  • Tony_C_Tony_C_ Member Posts: 277 PRO
    My sketching isn't working like that.  I did the same steps and when I paste onto the new plane the new sketch is shifted.
    I think your example is working because you're picking the circle whose center is already the origin. Try coping and pasting all three shapes and see what happens.
    I think when you just paste a sketch (from copied entities while not editing a sketch) onto a plane, OS is finding the center of that sketch and placing that center on the origin.
    Ahh, I think you are right. Let me dig into this further. Can you also fill out a feedback ticket on your end?
    @bradley_sauln
    I submitted a feed back ticket.
    There's also some info in the comments as to how I pasted each sketch.
    https://cad.onshape.com/documents/09c7422dd39727502ecb2251/w/46f9efadf6299bff5526d7da/e/7478b3c19607119a63f860b3
  • michael_watsonmichael_watson Member Posts: 15 ✭✭
    Can this behavior be changed? I have been annoyed by this "feature" as well to the point of wondering what's the point of pasting sketches. Seems like the default should place the sketch exactly to the same relation to the origin on the new sketch plane as from the the sketch plane it was copied.
  • jaydenlawsonjaydenlawson Member Posts: 3 EDU
    Agreed with Michael. Part of the reason for copying/pasting things is to align them. And since there's no simple and obvious way to align things, if you paste in the same place as the original, at least you can then use the transform tool to move the pasted thing along one axis, so it stays aligned in the other axes. As a new user, it strikes me as very odd that this simple method has not been used.  Same with no simple alignment tools.
  • andre_grondinandre_grondin Member Posts: 5
    Hello !
    I have the same issue with copy pasting the SKETCH it is not working an easy way , the animation is nice but way too fast so we can follow , there must be a betterway to be able to do a carbon copy of a sketch to another one on a similar plane without having to re-adjust ,
    thank you for all the help on this site it is very appreciated
    regards
  • eric_pestyeric_pesty Member Posts: 2,227 PRO
    edited November 2024
    If you want true carbon copy, you specifically don't want to copy paste!
    You can use something like the transform pattern FS https://cad.onshape.com/documents/25a0a6dfaa76e64574a5e0db/v/8217d6d96ccc324b8dd86160/e/4c62c06c4e0e4db3703a2d4c
    Or you could create a offset surface of the sketch (a flat face can be used pretty much anywhere you would use sketches) and use the "regular" transform tool (using transform by mate connector)
  • dakota_doldedakota_dolde Member Posts: 2
    "When you paste into a sketch that isn't active, the pasted entities get roughly centered on the origin."
    This is actively untrue, I've been trying to copy + paste entirely symmetrical sketches (vertically and horizontally) and despite having no elements of the sketch (construction lines, overhanging lines, etc) asymmetrical, an offset is created on both sketch axes.
  • glen_dewsburyglen_dewsbury Member Posts: 1,061 PRO
    As mentioned earlier, paste the sketch entities in a new sketch and it will activate transform. Make sure the transform center is moved where needed and drag handle until the origins snap together.
    If it is a simple sketch just start a new sketch and use the 'use' tool instead of copy and paste.
