Simple cutlist with measurements
quentin_sandberger
Member Posts: 4 ✭
Hello, im relatively new to onshape and i have a modeled bench in the part studio, now i want to have a cutlist where there are:
- Number of part
- How many of this part
- Measurements
- and maybe material or so
when i go on cut list theres only object and how many of it
maybe im too stupid and its really obvious but how can i add more attributes to the cut list?
thanks for helping
cheers
Interesting, just to confirm, you did use the Frame tool as well as the Cutlist too along with the Frame trim tool? If you used these to make the bench, the cut list should also show the measurements.
Yes, you can modify the cutlist feature to add whichever properties you like. Here is the Cut list+ feature which lets you name the parts based on their profile, length, and cut measurements.
If you get really serious about it, you can copy the feature an modify it yourself. If you follow the CADSharp FeatureScript video lessons, they will show you how to modify the cutlist feature.
RENDERCAD
