ZOOM JUST BROKE...?
Hey guys,
I am such a big Onshape fan. But today I saw the first time something seemed to brake. When editing a part, perspective turns off automatically. I do not recall that this was ever the case? Also, zoom is all messes up right now - two issues:
1. Zoom gets limited at a certain point - this is probably a result of the non-perspective limitation.
2. When I manage to get another angle to get closer to the part I am editing, the zoom direction changes dynamically and eratically.
What's up?
Never much use perspective mode but thought I'd see what the comment was about.
Certainly different. Pan for me has always been a 2d function but in perspective mode pan seems to be AROUND the perspective point. The RMB revolve seems the same but scroll in and out seems also to be AROUND the perspective point.
Certainly not what I'm used to or expecting.
It's hard to reproduce, but the essence is that if you zoom in until you can't zoom in anymore and then rotate to put the camera closer, scrolling to zoom in actually zooms out. Also, the zoom limit itself is not very consistent (occasionally not being present) and often doesn't let you zoom in as close as is needed for smaller details in large assemblies.
Here is a video where I zoom in by scrolling, then rotate, then zoom in by scrolling, then rotate... All of the zoom-outs are happening while scrolling to zoom in. Shift Z does not zoom in further when the zooming is stuck at its closest point or in cases where scrolling to zoom in actually zooms out.
https://cad.onshape.com/documents/1ca794d945877574cdcfe39d/w/34de9d1514852c0e6db40633/e/eb49e3f41a78cce6e0b5ac51
I have the same issue.
I am working on a flythrough presentation and would really appreciate if this issue could be resolved
Best Regards
