STEP file importing
When importing a STEP file which is an assembly, Onshape shows it as a breakdown of all parts but I cannot see the actual assembly.
lougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,014
@Richard_Radzim No mates will not come over. Mates are relationships that are built differently and there is no universal way to convert them into another system.
Lou Gallo / PD/UX - Support - Community / Onshape, Inc.5
If there is not motion in your model, you can select all parts and set 'Group' mate and it will keep your assembly from braking. You can also select only the static parts and recreate mates for moving parts.
Remember to set 'Fix' for one of the static parts to keep model fixed relative to origin.
