Problem with OnShape
peter_marsh559peter_marsh559 Member Posts: 6
Working through the introductory tutorials of OnShape. One command that does not work on my system is the curve constraint command. Not sure what I am doing wrong but it should be a simple double click to turn two segments into a curve. Do this over and again and two lines remain. Not a huge problem but one day I may want it to work..
Any help would be gratefully appreciated .
  • rafael_telgmannrafael_telgmann Member Posts: 138 ✭✭✭
    The curve constraint ensures that two curves (e.g. Bézier curves) have the same curvature at the connection point. This constraint does not turn straight lines into curves.
  • MDesignMDesign Member Posts: 1,286 PRO
    Well that was anti climatic. 😂
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,961 image
    @MDesign check your spelling 😀 although it did understand what you meant
    @NeilCooke I always misspell that word for some reason. ugh. Grok and chatgpt don't care if I misspell something. 🤣
    Here's a revised screenshot with corrected spelling. 🙄
    @peter_marsh559 This link should help you find answers fairly quickly for things like constraints. https://learn.onshape.com/pages/ai-advisor
