Improvements to Onshape - June 27th, 2025
2»
    edited June 30
    @GregBrown thanks for the explanation link
    I like simulation a lot and beat it up all the time. Last year I tried something that shouldn't have worked and I reduced the constraints on my simulation. There are a lot of things turned on in simulation that help you get your analysis work done. Simulation has had some kind of mesh stabilization working because I got answers last year that seemed real. Maybe it was "soft spring" or better "inertia relief". I did a sudo validation by cutting the bracket in half and fixing the cut making the problem into a simple beam problem. The results matched the mesh stabilized results and I had some confidence.
    I've always wondered how initial relief stabilized the mesh and I now have a better idea. I'm supposing they use the 1st modal shape to figure out how the part is going to deform and give us a shape. But without material damping, I'm not sure how they predict the magnitude of the shape. It must be some kind of worse case scenario.
    I do have a prototype part and I'm validating my analysis as I go. I'm doing a differential analysis allowing me to make changes to the model and determining if the design is getting better or worse. I can easily do this in the computer with confidence.
    The prototype was printed and now my molder is bitch'n at me about draft & sink. I've made the changes to the model and want to determine if the bracket is weaker or stronger. This is how I use analysis saving on building prototypes.
    Anyway, I need to analyze may design changes now that I've got "inertial relief" dialed in and recommend others do the same.
  • sebastian_glanznersebastian_glanzner Member, Developers Posts: 454 PRO
    Great update!
    Onshape feels so much faster, was the performance improved when opening large assemblies?
  • PattabiPattabi Member Posts: 54 ✭✭
    SUPPRESS FROM THIS BOM & CALLOUT HIGHLIGHTING are two useful improvements. Thank you!
  • Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 256 ✭✭✭
    How can I ensure that the last layout of the new document page is displayed on a fresh start?
    Henk de Vlaam (NL)
    I liked the previous document page better. But if the current one stays in this form - which I hope not - I would like to have the Label visible in the document list. So like before.
    Henk de Vlaam (NL)
    What I mean by that is that the setting - for example the 'Last opened by me' and the 'Folders' panels collapsed - is remembered.
    Henk de Vlaam (NL)
    Yeah, I'm not a fan of the new layout.
    The lower list of documents takes up too much room, and since 95% of the documents I use are in folders, that is a spot I never go to for documents.
    I much preferred seeing more folders. I know you can drag the slider down, but you have to do that every time; it doesn't just stay down.
  • STEGSTEG Member, User Group Leader Posts: 125 PRO
    First time I'm really disapointed by an update. The new layout of the documents pages is a lost in efficiency and clarity for me. I want the old layout back please.
  • romeograhamromeograham Member, csevp Posts: 713 PRO
    I prefer the old Documents page at the top level only. Once I select a Project (we use Projects in our Enterprise) or Folder, I like the "content-forward" presentation of the new documents page. It's that top-level page of Project and miscellaneous documents (that really belong in Projects or Folders) that is the problem.
  • GWS50GWS50 Member Posts: 455 PRO
    Yes having labels in the document line was really useful. Collapsing the folders tab every time is a pain and everything seems less clear somehow
  • YWC_BrencisYWC_Brencis Member Posts: 15 PRO
    Grid view not being available for searching Documents is a big minus. Both while browsing through folders or using search. Hopefully that can be added to the UI.
    Am I missing something or are the Lables also not available in the document view anymore?
    Thanks for considering the comments for future updates.
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 140 PRO
    Anyone placing bets on updates this month?
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 878 ✭✭✭✭✭
    Sheet metal Loft. :) Right @sebastian_glanzner
    Bryan Lagrange
    Twitter: @BryanLAGdesign
    @bryan_lagrange Haha, yes! Where is sheet metal loft 😀
