New Custom Feature: Animate
NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,873
edited November 2024 in FeatureScript
Onshape's Animate feature can only animate one mate at a time. Adding gear relations between mates can make animations more interesting, but if you need an animation showing a sequence of events, then there is no easy way to achieve this other than using the amazing (but manual) technique developed by @john_mcclary
This custom feature expands on John's method and adds a level of automation. Below is a tutorial video showing all the steps to animate a UR Cobot, from building the animation timeline to adding the relevant gear relations in the assembly. Apologies for the length of the video, but it does go into a lot of detail. Please leave any comments or suggestions below.
Animate - Custom Feature: https://cad.onshape.com/documents/8afc165187d023c4d83554ff
https://onshape.wistia.com/medias/05cp9kvlxv?embedType=async&seo=true&videoFoam=true&videoWidth=1280
  • S1monS1mon Member Posts: 3,376 PRO
    I have to agree with @ben_partouch , this is both amazing and clearly needs to be a real piece of functionality. This is much better than nothing, but anyone doing animation is going to want to be able to drag break points around on a timeline much more graphically. It's nice to be able to control things in real physical values (e.g. m/s and m^2/s), but visually controlling things is often preferred. Being able to drag the assembly directly and record a position and then have Onshape animate between those positions would be a much more typical approach.
    I'm also surprised that the ease-in ease-out is only rounded for linear motion. It's probably good enough for basic animation, but if you look at 3D animation tools or motion graphic tools, there are typically a large number of ease-in/out options.
  • MichaelPascoeMichaelPascoe Member Posts: 2,427 PRO
    Thanks for this feature Neil! Looks like you put a lot of work into it.
  • billyzelsnackbillyzelsnack Member Posts: 96 ✭✭✭
    This is insane. Both definitions. I love/hate it so much.
  • EvanReeseEvanReese Member, Mentor Posts: 2,448 ✭✭✭✭✭
    Neil, this is really amazing! Your features are always so thorough. Clever how you're making the first feature UI look different from subsequent ones.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,873
    @jan_bouwman although I wrote this for a customer, your original post inspired me to get this done!
  • MDesignMDesign Member Posts: 941 ✭✭✭
    Wow! speechless. That's amazing. Bravo!!
  • jan_bouwmanjan_bouwman Member Posts: 17 EDU
    @NeilCooke
    Nice to know.. You’re welcome 😀
    Btw, the voice clone is getting better! Doesn't feel like the real Neil, but it is pretty good.
    @MichaelPascoe haha actually that is me, but it was done in a rush.
    What!?? 🤣
    The clipping threw me for a loop. I would have bet and lost money on that.
    @jan_bouwman That animation is in Onshape?! 🤯 great job
  • jelte_steur814jelte_steur814 Member Posts: 498 PRO
    Beautiful application of FS.
  • STEGSTEG Member, User Group Leader Posts: 124 PRO
    Wow! What a great feature! 👏
    Also the kind of thing that makes me feel dumb by the way… 🤪
    @EvanReese yes, these animations are all in Onshape and run ‘real time’. No video editing other than some trimming. :-)
    Great fun to make, however time consuming.
  • gerry_friedmangerry_friedman Member Posts: 3 ✭✭
    I've been working with this custom feature for a while now on a number of animations.
    Don't know what the issue is but some of the motions are not smooth (have hiccups I call it) and speeds are not consistent (speed up or slow down).
    In doing a presentation I've put my model into the "perspective view" and really see these issues show up more. May be upload and download speeds have something to do with this. Any suggestions? (also running on a late 2013 iMac)
    I'd like to suggest in preparing a timeline, it would be nice to be able to "insert a step" and have subsequent steps shift. This would avoid having to rewrite everything.
    I've also found the animation step limitation to be 3600 which affects speed. Could use a larger number to slow long motions down. (I've got hundreds of feet of travel in some models.)
    Otherwise, thumbs up for this feature.
  • Ste_WilsonSte_Wilson Member Posts: 479 EDU
    That is a thing of wonder! Fantastic.
