Force a workspace to update Library Version?
Sometimes old workspaces in old documents don't get updated for some time or at all, but I want to work in there again with the latest feature set. For example I'm in one that still doesn't have thin extrudes and face blends.
If I were to try to merge it into a workspace that had been updated it would let me know about a library version mismatch and prompt an update, but how do I force it to update without a merge?
You could version the workspace, then branch it again. This will let you update the new branch. Might not be an option for you if it is a public feature and your trying not to notify everyone of a false update. But then again, we have the option to publish now so that may fix that issue?
Perhaps I misunderstood. Updating a workspace to the latest Onshape version right?
https://thesmoothcut.com/
chadstoltzfus@premiercb.com
The "version/derived manager that works across documents" is exactly what I'd like to see in Onshape's core functionality. So that the "update all" button (or a separate checkbox) literally updates all (even derived parts coming from outside the current document), not just the items located in the current document.
Thank you! This worked perfectly.
Trashing and restoring didn't work for me FYI :/
I just trashed and restored a document, and branches didn't get updated. Merging with mismatched versions is really really really painful.
I think the move might be to delete branch workspaces immediately after they are merged back to main. And if they were never merged, the idea probably died and the workspace can still be deleted. Then there is nothing to update except the Main workspace. Every time I open an old document now I go through its version graph and do this.
It only takes a day (if you hit the wrong part of the 3 week cycle) for one branch to become out of sync. Then it makes merging much more complicated. And as mentioned in another thread, with workspace protection on it’s even worse. This is quickly becoming a top issue for my company.
Is this still true for documents with Branches? We're having challenges merging branches. With many people on a team, it's hard to keep people out of a document for a scheduled update that never seems to happen when it says it will, and Trash/Restore didn't seem to do the trick for branches.
Yes. I also work with several customers on Onshape data that they own. My team doesn't always have the authority to trash/restore our customer's data to trigger workspace updates. In cases like this it becomes even more convoluted. This happened to me two weeks ago and due to the issues with others accessing, etc. we basically lost a full day working in that document and had to delay an important prototyping milestone.
This is really frustrating. I am completely broken down because the one document I randomly need to work on today is not updated, so I'm just sitting here clicking refresh on my email, hoping someone actually reads my support ticket.
Why do users not have the option to force an update? I understand why the update goes out on a rolling basis… but if I can't opt out of an update, I need to be able to force an opt in!
@Michael_Bills Please tru Hamburger menu/Update workspace.
I have now tried trashing the document and restoring it. It did not solve the issue.
This is the second time it happens to us. It is not even an old document in both cases it was the document I was actively working on.
The first time it happened I just started all over again, as it happened after only 2 hours of work. But now we have a project that cannot move forward and apparently no way to fix it without external help.
I consider this a very serious issue for a professional tool. At least SolidWorks crashing was something that allowed you to work again after a few minutes, even if it took a hard reset of the computer.
@Jan_Stegmann Might be missing something, but have you tried this new-ish option?
"Update workspace…" worked for me for copying simple shapes that had been throwing an error.
