Hi Neil, thanks a lot for the help.
I didn't import a csv file, and hopefully i can skip it all together. Partly because during design phase wiring tags have not been decided yet. Wire it in CAD and name them later would be ideal.
I have tried to select the "pin curves, faces, or edges" on different surfaces at the back of the connector, but couldn't, system will just deselect what i clicked.
Thanks @ken_xu for sharing your doc with me. For anyone else encountering this:
You need to always add a pin number to the wire ref definition. If you do this before selecting the part, the curve in the connector will get selected automatically. The reason it was deselecting the curve was because there was more curves selected than pin designations. The fix will be to make the pin entry mandatory, but for now, please add a pin number.
Man I can't wait to fork this Featurescript and reskin it as plumbing.
Yes @Derek_Van_Allen_BD please make this a reality😎, I worked at a Solidworks Reseller once and a plugin there for PI&D 3d "plumbing" is this: https://www.smap3d.com/en/cad-integrations/solidworks
But the usability is far from good, would be cool to see a useable Onshape Feature Script emerging in this field.
Please give me an update, when you are pushing stuff like this
forward: https://www.linkedin.com/in/martin-meingassner-65093269
thx & rock on,
Martin
Added more wire colours and abbreviations:
@NeilCooke - I have a connector that has entry and exit on opposing sides. However when I define the terminals they are all in one single (same) direction, so the wire exits into the connector through itself. Is there a way of fixing this without splitting it into two connectors? P.s. inputs are wrong colours, just spotted!
Update: when you define the connector you can only choose the same direction for all pin outs. When you create a wire reference and you then pick the composite part connector, all the CSV wire references assume the same direction as the connector definition and it doesn't align as it should. In the case of above, you have to manually create the wires from the terminal faces and then it works. So there is no point defining the connector in this instance.
@NeilCooke - since the last recent wiring update, I cannot seem to route wires through clips or sketches anymore. It seems to generate an error. If you route a wire routed through a clip/channel - when you click to create cable if loses info about the clip routing as well.
Have you noticed this?
I haven’t but happy to investigate. Double- checking: it only uses the clip routing of the first wire and ignores the rest.
I submitted a support request. Appreciate it if you wouldn't mind taking a look, @NeilCooke.
Hi Dean, while looking at this, I discovered that you can add a second Wire connector>Define feature to your connector library model and define more pins with different directions. When you create the Wire ref and Wire route features it seems to work as expected. Could you test for me? Thanks.
EDIT: Verified fixed in 1.194.0
There is currently an issue with the latest update of Onshape that is conflicting with the Wire features, causing clip selection and clip direction flipping to fail on new Wire route features or when existing ones are edited. Existing un-edited routes are not affected. There are two current workarounds that can be used until this issue is resolved:
1. After selecting clips, press the reset button on the "Edit wire" menu. This will fix the clips but you will be unable to flip their direction. Also, pressing the reset button will remove all wire edits in that feature, so please use with caution.
2. Use the Wire route feature from version 1.179.2 for all new wire routes.
We are working to get this issue resolved. Apologies for the inconvenience.
This looks really useful - I'm interested in how this interacts with the BOM? How, if at all, are the wires/cables/connectors managed in the BOM table, particularly in regards to the Onshape-Arena connector?
Hi Emily, currently a cable or harness is treated as one item with one part number.
That's great! Thanks for the speedy response Neil.
Issue verified fixed in 1.194.0 - thank you for your patience.
Sorry @NeilCooke - I got busy on other stuff. I will test adding a second wire connector as you suggested and report back.
Hi All,
Is there any info on how to create a clip etc. @NeilCooke
Hi Carl, placing a clip is shown here https://forum.onshape.com/discussion/comment/99289/#Comment_99289
Changelog for release 1.195
⭐ Clip definition and library part creation has been simplified and improved.
⭐ Fixed an issue with minimum bend radius information not being displayed while editing a wire.
@NeilCooke Now that Routing curve has been officially released, is cabling far behind?
@S1mon built-in applications for piping, tubing and wiring and their industry-specific workflows are certainly not imminent. It is recommended to use the Routing curve for simple wiring applications and use my features for more complex setups, especially those driven by wiring schematics.
Changelog for release 1.195.2
⭐ Fixed an issue where other wire errors cover the minimum bend radius violation notice.
While editing a wire, the minimum bend radius notice now takes priority.
Changelog for release 1.197.1
⭐ Added wire color to wire data table
⭐ Added 4/0, 3/0 and 2/0 nomenclature to AWG size in the Wire data CSV parsing function
I'm aware harness flatting isn't yet available. As an interim solution is it possible from the wire data table to get the length of the bundles and locations in order to help in the manufacture of the harness?
E.g. the length of the blue section then the subsequent lengths of the black and grey sections from that?
Changelog for release 1.198.0
⭐ Fixed issue in Wire clip feature when deleting unused clips
⭐ Swapped position of "Insert" and "Define" menus in Wire clip feature to be consistent with the Wire connector feature
Internal clip IDs are now more robust - if an unused clip is deleted from a Wire clip feature, downstream Wire route features will not be affected. This capability can be enabled on existing Wire clip features by editing the feature and making a simple change to update the feature (e.g. switch from Insert to Define and back again).
Changelog for release 1.198.1
⭐ Fixed issue with CSV files containing spaces
Hi @NeilCooke ,
I have been using wire routing feature script recently. This is an awesome feature. Thank you for this. I am looking into creating drawing based on the routing that is complete. Couple of requests from my end:
Greatly appreciate any help here.
The flatten feature is well advanced but requires some other dependencies to be competed first. Plan is sometime during the summer for first release.
Being that I'm working on a "frame flattening" feature at the moment, can you give any insights on what those dependencies might be? I might be barking up some of that same tree over here.
Changelog for release 1.201
⭐ Added per-segment reset. Select a segment to edit first, then click the reset button.
⭐ Add route point UX has been improved for clarity and consistency.
⭐ Addition and removal of clips keeps route edits intact.
⭐ New "nudge" option provides mechanism for moving edit points between route segments.
Note: this update does not guarantee backwards compatibility - please see video for details.
