Creating a cylinder using API
hari_haran541
Member Posts: 7 ✭
in General
Hello all,
I am trying to create a cylinder with API , but unfortunately i couldn't,
i can create a empty document to my account but, when i try to add a sketch in it it throws a error saying unsued filters ,
i tried removing filters from my code too but still facing the issue , Does someone already gone through this before..?
I would appreciate any solution or recommendation on This.
Thanks in advance.
@hari_haran541 : We have an example here : https://onshape-public.github.io/docs/api-adv/featureaccess/#create-a-cylinder
hi @Paul_J_Premakumar , Thanks for the input,
I'm having trouble with the
onshape-clientfor Python. I tried running the official documentation example to create anewSketch, but it fails with anInvalid input arguments... unused input data is {'filter': ...}error. The strange thing is, the official example for creating a simplecubeworks perfectl.Can you help me to overcome this ..?
@hari_haran541 : Can you share your code & the exact error message (line number etc..) you are getting. This will help in debugging the issue.
Hi @Paul_J_Premakumar
Thanks for getting back to me!
Yes, of course. Here is Python script I am using to test for creating a
newSketch, along with the full error message I'm receiving.The Python Code:
The Python script authenticates correctly and successfully creates a new, empty document in my Onshape account. However, the script fails on the next step when it tries to add the
newSketchfeature.The Exact Error Message:
The script successfully creates the document but fails on the
add_part_studio_featurecall with the following error:Failed to create sketch: Invalid input arguments input when making an instance of class BTMParameterQueryList148. Not all inputs were used. The unused input data is {'filter': {'btType': 'BTOrFilter-167', 'operand1': {'btType': 'BTOrFilter-167', 'operand1': {'btType': 'BTAndFilter-110', 'operand1': {'btType': 'BTGeometryFilter-130', 'geometryType': 'PLANE'}, 'operand2': {'btType': 'BTFlatSheetMetalFilter-3018', 'allows': 'MODEL_ONLY'}}, 'operand2': {'btType': 'BTAndFilter-110', 'operand1': {'btType': 'BTAndFilter-110', 'operand1': {'btType': 'BTSMDefinitionEntityTypeFilter-1651', 'smDefinitionEntityType': 'FACE'}, 'operand2': {'btType': 'BTFlatSheetMetalFilter-3018', 'allows': 'MODEL_AND_FLATTENED'}}, 'operand2': {'btType': 'BTGeometryFilter-130', 'geometryType': 'PLANE'}}}, 'operand2': {'btType': 'BTBodyTypeFilter-112', 'bodyType': 'MATE_CONNECTOR'}}}It seems like the Python client library is incorrectly rejecting the
filterparameter when creating aBTMParameterQueryList148object. I tried creating a simple cube from the example it works perfectly but this failed.Thanks in advance for your help in debugging this!
@hari_haran541 : The python client is no longer being updated. It can be used for authentication, but beyond that the other calls are not guaranteed to work.As a workaround instead of calling the
part_studios_api.add_part_studio_featureyou can construct the required params and call the GET/POST methods using the genericclient.api_client.requestor one of the python library REST api calls.
