Improvements to Onshape - August 7th, 2025
CAD IMPROVEMENTS
EDIT SKETCH PATTERN
In sketch patterns, such as linear and circular patterns, you can now add and remove instances and sketch entities after initial creation.
CONFIGURATION VISIBILITY CONDITIONS
New options rules are available to dial in which values should be present based on other inputs. Human readable parameters now show when values are collapsed. A new undo/redo function is at the bottom of the screen and the right-side preview provides greater clarity now that the panel shows "hidden values" by default.
FRAMES AND FORMS LIBRARY SEARCH FILTER
CURVE DEVIATION
Onshape introduces the Curve deviation tool, designed to streamline the process of checking curve alignments. Accessible via the Analysis tools in a Part studio, it provides instant feedback on minimum and maximum deviations.HIDE OR SHOW BEFORE SETTING ASSEMBLY CONTEXT
VARIABLE STUDIOS
WORKSPACE UNITS
Mixing different unit systems in your Workspace is now possible.MATERIAL UNITS
EXPORT INNER LOOPS FOR FLATTENED SURFACES
Surface flattening has been enhanced to support inner edges during the export process.DRAWINGS IMPROVEMENTS
NEGATIVE DIMENSION VALUES
Change the value of a sketch dimension relation to a negative value.
COPY AND PASTE TABLE DATA
LOCKED HEADER ROW FOR INSPECTION TABLE
DATA MANAGEMENT IMPROVEMENTS
LIST VIEW COLUMN SORTING AND PART HIGHLIGHT
ASSIGN A TASK TO MULTIPLE USERS
DOCUMENT RECOVERY
RENDER STUDIO IMPROVEMENTS
FOLDER IMPROVEMENTS
CUSTOMER SUPPORT IMPROVEMENTS
CONTACT SUPPORT
Ah mixed unit systems. One step closer to properly documenting my 1/4"-20 x 20mm threaded inserts the way the manufacturer intended with units defined arbitrarily on a per-dimension basis.
A happy surprise to the day! Pumped for the configuration additions.
👍️Thank you for the comprehensive update, full of great new improvements.
Onshape is too complicated, I quit. Just Kidding! Nice round of updates, and still some unpacking to do. Configuration option and copy paste drawing table to spreadsheet are 2 big hitters to me.
It would be nice to be able to grab a deviation measurement along any point of the geometry, not just min and max. Here I'd like to measure at the point circled in red the maximum deviation. Of course I could trim my curve but that would require extra features and not possible from a version.
Lots of quality improvements here. We appreciate each of these. I particularly like the Frame Library and Variable studio improvements.
Thanks Onshape Team! 🎉
This is an awesome release! Love the attention to configs for making really thorough setups. Curve deviation is interesting, but I'm curious which scenarios Onshape expects it to get the most use. The sketch pattern update is great. I've had to either stack patterns or recreate them many times.
Now to do my tri-weekly scheduled snooping through featurescript fragments and see if I can't brute force preview future functionality. I already see some things for query variables that I know @MichaelPascoe is gonna be interested in.
Lots of great quality of life improvements here - editing sketch patterns, config visibility power, reordering variables, etc..
One thing I will request again - PLEASE add the date that a revision was released to the columns in the list or structure view, and PLEASE make it so that the results can go recursively down a folder structure. As it is right now, these views are almost useless if we keep parts and assembly documents in folders within a project. I want to see an overview of released things for a project. We're manually collecting this information in a publication now. Not being able to sort by date seems so fundamental.
https://forum.onshape.com/discussion/24583/allow-list-view-to-descend-folder-tree
https://forum.onshape.com/discussion/27217/structured-view-sort
Hype! This is some really exciting stuff
Density seems to have defaulted to pounds per cubic inch, even for those of us that have set everything else to metric.
Is there any way to batch-update documents to use kilograms per cubic meter? We have the
/api/documents/d/{}/{wvm}/{}/unitinfo
to get the units, but nothing to update them.IR for AS/NZS 1100
great updates, especially the pattern and configuration, looking forward to more.
Very excited about the pattern editing and flatten surface improvements - immediate time savers for our workflow.
i used it a lot when trying to make nice curves on top of scan data
nice update, the edit sketch pattern is awesome. But I have an issue, we have discovered all our older documents units have change and gone to imperial! NOT GOOD. Has anyone else have this issue?
Great update. Looking forward to trying the new configurator.
Love the pattern update, me too has had instances where I had to redo them because afterwards I realised it was too many or not enough. Great stuff this.
I was thinking for a short time that maybe mixed units should be possible accross one item, length for instance, but even though I know of machines that mix these in real life, it is a ridiculous notion so perhaps better not request inches and mm posibility in one sketch 😶
Amazing updates! My only complaint is that the sound volume of the videos keeps changing… 😁
OOOW, I also wanted to say that bit I forgot 😂🤣
Yep, same for us. Not looking forward to having to manually reset everything!
I found that in many of my export settings to export a dwg or wxf, the preset unit in the export changed to meters opposed to the mm that it was before. This means the exported files are a factor 1000 smaller. Not sure if it has to do with this update but the last few days I have had this happen.
The most annoying thing is that I can set it back to mm but it only stays to mm in that session for that document. I open another document and the setting is back to meters.
EDIT!
It now seems to stay on mm, lets hope this will remain the case.
amazing🤩👏👏
