Improvements to Onshape - August 7th, 2025
mlaflecheCADmlaflecheCAD Member, Onshape Employees, Developers Posts: 187
edited August 7 in New in Onshape
It's Thursday and we have a release chock full of goodies. This release contains a wide variety of features and improvements to usability, Configurations, Drawings, Render Studio, and more. Let's dive right in!
CAD IMPROVEMENTS
EDIT SKETCH PATTERN
In sketch patterns, such as linear and circular patterns, you can now add and remove instances and sketch entities after initial creation.
https://onshape.wistia.com/medias/gczlcbtyue
CONFIGURATION VISIBILITY CONDITIONS
New options rules are available to dial in which values should be present based on other inputs. Human readable parameters now show when values are collapsed. A new undo/redo function is at the bottom of the screen and the right-side preview provides greater clarity now that the panel shows "hidden values" by default.
https://onshape.wistia.com/medias/irt8ca2ut4
FRAMES AND FORMS LIBRARY SEARCH FILTER
When inserting Frame elements or Sheet metal Forms from your library, you can search by name, size and configuration, rather than scrolling through dropdown lists.
https://onshape.wistia.com/medias/d0o1bmoe3c
CURVE DEVIATION
Onshape introduces the Curve deviation tool, designed to streamline the process of checking curve alignments. Accessible via the Analysis tools in a Part studio, it provides instant feedback on minimum and maximum deviations.
https://onshape.wistia.com/medias/owh2ncexo1
HIDE OR SHOW BEFORE SETTING ASSEMBLY CONTEXT
It is now possible to hide or show components before setting the initial context for your Part studio for in-context design.
https://onshape.wistia.com/medias/xq1jmwbo85
VARIABLE STUDIOS
As with configurations from the last update, you can easily reorder values and Variable Studios in the Variables panel as well as collapse and expand all.
https://onshape.wistia.com/medias/ftb2hk2yl9
WORKSPACE UNITS
Mixing different unit systems in your Workspace is now possible.
https://onshape.wistia.com/medias/4wcpv4d929
MATERIAL UNITS
Mixing unit systems for material libraries allows for preferred units and simplifies the import and export of custom material libraries.
https://onshape.wistia.com/medias/ktd9nq4uxu
EXPORT INNER LOOPS FOR FLATTENED SURFACES
Surface flattening has been enhanced to support inner edges during the export process.
https://onshape.wistia.com/medias/c2u2tjf8m6
DRAWINGS IMPROVEMENTS
NEGATIVE DIMENSION VALUES
Change the value of a sketch dimension relation to a negative value.
https://onshape.wistia.com/medias/dwi3wzr5at
COPY AND PASTE TABLE DATA
You may now copy and paste individual cell and table data in many ways; both internal to an Onshape drawing, or external to a spreadsheet or text editing application.
https://onshape.wistia.com/medias/m7w66x0oro
LOCKED HEADER ROW FOR INSPECTION TABLE
The top row of the Inspection list is fixed in place for better readability when viewing long inspection lists.
https://onshape.wistia.com/medias/ou6rxxbblp
DATA MANAGEMENT IMPROVEMENTS
LIST VIEW COLUMN SORTING AND PART HIGHLIGHT
Improved sorting options by Part number, Revision, and State in List view. Additionally, when opening from List view, Structure view or search results, individual components appear in Isolate mode within a multi-part studio.
https://onshape.wistia.com/medias/m2r8t2gsff
ASSIGN A TASK TO MULTIPLE USERS
Multiple users can be assigned to a single task, allowing one to complete that task.
https://onshape.wistia.com/medias/ovl3ju29ak
DOCUMENT RECOVERY
In the rare situation that a document needs recovery, the rich Onshape history is at your disposal, with new automatic options that appear if Onshape detects a slowdown that recovery can benefit.
https://onshape.wistia.com/medias/qpsjxrqvhh
RENDER STUDIO IMPROVEMENTS
FOLDER IMPROVEMENTS
Folder names are included in the Search filter, and Folders with their contents, can be suppressed or used for other operations.
https://onshape.wistia.com/medias/ml3asm4cu9
CUSTOMER SUPPORT IMPROVEMENTS
CONTACT SUPPORT
The Contact Support tool has been redesigned to support selective capture and also includes an expandable text area for more descriptive details. It also supports external markups and attachments in addition to the internal markup toolset.
https://onshape.wistia.com/medias/ildyxqy5dx
Regards,
Mike LaFleche   @mlaflecheCAD
«1
  • Rhett_RobinsonRhett_Robinson Member Posts: 159 PRO
    A happy surprise to the day! Pumped for the configuration additions.
  • ladislav_pochopladislav_pochop Member, HON-TS, pcbaevp Posts: 10 PRO
    👍️Thank you for the comprehensive update, full of great new improvements.
  • Nick_HolzemNick_Holzem Member Posts: 158 PRO
    Onshape is too complicated, I quit. Just Kidding! Nice round of updates, and still some unpacking to do. Configuration option and copy paste drawing table to spreadsheet are 2 big hitters to me.
    It would be nice to be able to grab a deviation measurement along any point of the geometry, not just min and max. Here I'd like to measure at the point circled in red the maximum deviation. Of course I could trim my curve but that would require extra features and not possible from a version.
  • MichaelPascoeMichaelPascoe Member Posts: 2,499 PRO
    edited August 8
    Lots of quality improvements here. I appreciate each of these, particularly the Frame Library, Variable studio, and Render studio improvements.
    Thanks Onshape Team! 🎉
  • EvanReeseEvanReese Member, Mentor Posts: 2,516 PRO
    This is an awesome release! Love the attention to configs for making really thorough setups. Curve deviation is interesting, but I'm curious which scenarios Onshape expects it to get the most use. The sketch pattern update is great. I've had to either stack patterns or recreate them many times.
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 187 PRO
    Now to do my tri-weekly scheduled snooping through featurescript fragments and see if I can't brute force preview future functionality. I already see some things for query variables that I know @MichaelPascoe is gonna be interested in.
  • imants_smidchensimants_smidchens Member Posts: 65 EDU
    Hype! This is some really exciting stuff
  • ken_xuken_xu Member Posts: 11 PRO
    great updates, especially the pattern and configuration, looking forward to more.
  • Kyle_BasarichKyle_Basarich Member Posts: 2
    Very excited about the pattern editing and flatten surface improvements - immediate time savers for our workflow.
  • joshtargojoshtargo Member Posts: 412 EDU
    i used it a lot when trying to make nice curves on top of scan data
  • Ben_Tek_PacBen_Tek_Pac Member Posts: 53 PRO
    edited August 8
    nice update, the edit sketch pattern is awesome. But I have an issue, we have discovered all our older documents units have change and gone to imperial! NOT GOOD. Has anyone else have this issue?
  • brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,146 PRO
    Great update. Looking forward to trying the new configurator.
  • kees_bijkerkees_bijker Member Posts: 155 ✭✭
    Love the pattern update, me too has had instances where I had to redo them because afterwards I realised it was too many or not enough. Great stuff this.
    I was thinking for a short time that maybe mixed units should be possible accross one item, length for instance, but even though I know of machines that mix these in real life, it is a ridiculous notion so perhaps better not request inches and mm posibility in one sketch 😶
  • TillysInteriorsTillysInteriors Member Posts: 5 PRO
    Amazing updates! My only complaint is that the sound volume of the videos keeps changing… 😁
    OOOW, I also wanted to say that bit I forgot 😂🤣
  • Matt_NCMatt_NC Member Posts: 7 PRO
    Yep, same for us. Not looking forward to having to manually reset everything!
    edited August 8
    I found that in many of my export settings to export a dwg or wxf, the preset unit in the export changed to meters opposed to the mm that it was before. This means the exported files are a factor 1000 smaller. Not sure if it has to do with this update but the last few days I have had this happen.
    The most annoying thing is that I can set it back to mm but it only stays to mm in that session for that document. I open another document and the setting is back to meters.
    EDIT!
    It now seems to stay on mm, lets hope this will remain the case.
  • didi_sunardi945didi_sunardi945 Member Posts: 6
    amazing🤩👏👏
  • adrian_vlzkzadrian_vlzkz Member, pcbaevp Posts: 295 PRO
    Quite a chunky update, great work everyone!
    CAD Engineering Manager
  • marcell_mágorimarcell_mágori Member Posts: 2 EDU
    I only use the pattern tools mentioned here, but I rely on them a lot, so this upgrade is very helpful! Thanks a lot!
  • Alex_PittAlex_Pitt Member Posts: 73 PRO
    All good improvements! Especially sketch patterns, config viz conditions and Render Studio folders. Many thanks!
  • Chris_KellyChris_Kelly Member Posts: 8 EDU
    I'll echo that the addition of configurable visibility of specific options is a game-changer, but currently because you cannot select the whole range of options it's quite limited. I appreciate the workaround, I might implement that for something I'm working on if a fix isn't pushed soon.
  • JosefBurjetaJosefBurjeta Member Posts: 30 PRO
    A lot of cool stuff, I really like the new edit within pattern and hide/show while creating In context Part Studio… yet I have two questions:
    Is there a set time limit when "Document recovery" will popup?
    Is it possible to implement a "threshold display" for Curve deviation? Something similar in Dihedral analysis. It would be great to see "deviations from 0,2 to 0,5 mm" in one color and anything above and below in different ones. I've already created #388295 for it.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,959 PRO
    A lot of good stuff this round. Awesome work!
    edited August 11
    First time needing visibility conditions since the updates:
    Am I missing something obvious? I'm trying to do a simple "Only show rotation_a" if "angle_a" is not 0 deg.
