Best use of derived sketch?
alexander_potochkinalexander_potochkin Member Posts: 45 ✭✭
Hello
I have two part studios and now I need to add a similar feature to both of it.
This feature should be multiplied and used in several part of the existing details.
So I created a separate sketch and now I am going to derive several copies of it
and use them in both studios.
I can't figure out how to correctly place a derived sketch to a particular plane.
Is it possible at all?
Can I derive a sketch many times within one part studio
and use different copies of it in different planes?
Thanks
    If you don't care about the parametric link you could just use the sketch copy and paste. The best thing about this is it takes all the dim's and constraints as well.
    Derived sketches in Onshape are currently a faint foreshadow of what they will (hopefully) be in future.
  • alexander_potochkinalexander_potochkin Member Posts: 45 ✭✭
    why not make one body that has the shape of the feature you want to add/remove. Then you derive this body into your designs, and use the move feature (with mate locators) to multiply and locate multiple copies of this part all around the design. Then you can use the boolean operation to subtract/add the feature to the design.
    Using the boolean operator you can specify all the bodies to subtract/add (tools) and all the bodies to add/subtract (targets) in one go.
    It seems to me that you would have a much easier job of doing changes in this way.
    Hope this helps you (I wish I was smart enough to do one of those giffy movie thingies, but alas I am not)
    I also tried to derive a separate part instead of a sketch. The same problem - it is not clear how I can reposition the derived part to a specific place in my part studio. I need to add it in one side of my part and subtract from another side. This is a static design, so I don't use assemblies and mates.
    Unfortunately I do care about the parametric link, so I need to tweak this derived part so it changes in all the places.
    Hello Andrew
    Thanks a lot for your suggestion on using the derived parts together with "transform with connectors" feature!
    I didn't realize it was so easy to do.
    Have a great day!
