Best use of derived sketch?
alexander_potochkin
Member Posts: 45 ✭✭
Hello
I have two part studios and now I need to add a similar feature to both of it.
This feature should be multiplied and used in several part of the existing details.
So I created a separate sketch and now I am going to derive several copies of it
and use them in both studios.
I can't figure out how to correctly place a derived sketch to a particular plane.
Is it possible at all?
Can I derive a sketch many times within one part studio
and use different copies of it in different planes?
Thanks
Thanks
joris_kofman
Member Posts: 59 ✭✭✭
why not make one body that has the shape of the feature you want to add/remove. Then you derive this body into your designs, and use the move feature (with mate locators) to multiply and locate multiple copies of this part all around the design. Then you can use the boolean operation to subtract/add the feature to the design.
Using the boolean operator you can specify all the bodies to subtract/add (tools) and all the bodies to add/subtract (targets) in one go.
It seems to me that you would have a much easier job of doing changes in this way.
Hope this helps you (I wish I was smart enough to do one of those giffy movie thingies, but alas I am not)5 -
andrew_troup
Member, Mentor Posts: 1,585 ✭✭✭✭✭
@alexander_potochkin
You can use "Transform" to move a derived part.
https://cad.onshape.com/help/index.htm#transform.htm
In your situation, possibly your best option might be to use Mate Connectors.
This was also mentioned in connection with Derived Parts in the last "New in Onshape" bulletin but one.
https://forum.onshape.com/discussion/1826/improvements-to-onshape-october-12-2015/p1
3. NEW: Transform with Mate connectors
5
Unfortunately I do care about the parametric link, so I need to tweak this derived part so it changes in all the places.
Thanks a lot for your suggestion on using the derived parts together with "transform with connectors" feature!
I didn't realize it was so easy to do.
Have a great day!
