Sweep for 3d parts?
alexander_potochkin
Member Posts: 45 ✭✭
Hello
I have two 3d parts and now I need to take one part and use it as a "bullet" to pierce through the other one.
I basically want to use a part as a tool to create a whole with a particular shape.
So I made a path to the tool part to go along and tried the sweep command for two parts.
Unfortunately it didn't work since the sweep command is designed for sketches.
Should I make a sketch out of my 3d "tool part" or there is an easier way to achieve it?
Thanks a lot!
Thanks a lot!
3dcad
Member, OS Professional, Mentor Posts: 2,477 PRO
Vote for improvement request if you need this feature:
https://forum.onshape.com/discussion/1957/solid-sweep
//rami5
There is currently no solid sweep capability in Onshape
Converting (Use/Project) edges from one part to a sketch may be your best bet to create a profile for sweeping
Without seeing your model it's not possible to provided a firm recommendation - a lot depends on the shape of the "tool" part, and the nature of the sweep path
I have created a ticket up for voting, I'll post a link when available.
I have created a simple test to illustrate what I am asking for:
https://cad.onshape.com/documents/497294dde6d7430daccb07c4/w/35ba91b8cf2c45b49165a3a1/e/fba4be4331de47d78cf99bfd
I need to "sweep" or "extrude" the sphere following the line from its center to the center of the cube.
So after that the cube should have a blind hole with rounded end.
My design is more complicated but this test illustrates it well.
If I make a sketch out of the sphere and extrude it I can get a blind hole in the cube .
The problem is that hole has plain end when I need it to match the sphere (rounded end).
I can imagine that I can create another sketch and dissect my "tool 3d object" one more time
and then somehow make the correct end of the hole.
This all sounds too complicated to me, so I am still under impression I am missing a very natural solution.
Any comments are very welcome!
Thanks
Thanks for your comment!
The boolean subtract is really the best solution to take out the 3d object out of another object.
I wish the "extruding" of a 3d part would be possible and it will eliminate the need to make so many steps
for this exercise.
If it is not possible for now I will use the plain/sketch/extrude/subtract solution.
Thanks again
In the example you give, I would probably just revolve a shape like this, specifying "Remove" in the same command:
Alternatively
A quick way to add a hemisphere to the bottom of your cylindrical extruded cut would be to add a fillet to the bottom edge, specifying the same radius as your sphereYeah, I likely end up using what you suggested.
Thanks much and have a nice day!
Something about the people on this forum tends to make it fun and rewarding to help out, and there's a particularly nice line in new entrants, I reckon.
Incidentally, I remembered another situation where I would definitely use a sweep with a straight path at present:
As a (reasonably satisfactory) workaround for the current inability to "Extrude up to vertex" in Onshape.
Thanks!
