Force a workspace to update Library Version?
EvanReeseEvanReese Member, Mentor Posts: 2,868 PRO
Sometimes old workspaces in old documents don't get updated for some time or at all, but I want to work in there again with the latest feature set. For example I'm in one that still doesn't have thin extrudes and face blends.
If I were to try to merge it into a workspace that had been updated it would let me know about a library version mismatch and prompt an update, but how do I force it to update without a merge?
  • MichaelPascoeMichaelPascoe Member Posts: 2,817 PRO
    edited December 2023
    You could version the workspace, then branch it again. This will let you update the new branch. Might not be an option for you if it is a public feature and your trying not to notify everyone of a false update. But then again, we have the option to publish now so that may fix that issue?
    RENDERCAD
  • EvanReeseEvanReese Member, Mentor Posts: 2,868 PRO
    Thanks, Michael. Branching again doesn't pull up any option to update that I'm aware of.
    Perhaps I misunderstood. Updating a workspace to the latest Onshape version right?
    RENDERCAD
  • xTimRicexTimRice Member Posts: 61 PRO
    Support can update if you send a ticket @Evan_Reese
    Handcrafted furniture in Boston
    https://thesmoothcut.com/
    Yes. The workspace doesn't have the latest toolset, but versioning and branching it doesn't give the option to update it.
    Thanks I'll give it a go.
  • kees_bijkerkees_bijker Member Posts: 171 ✭✭
    Has this been solved? I am trying to copy a sketch from one document into another and I get the same message of mismatched library. But I have worked in both documents today and I had to create up to date versions in each several times, so why did this not update the library also?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,988 image
    @kees_bijker a new update was pushed last night so one doc has been upgraded and the other hasn't yet.
  • rick_randallrick_randall Member Posts: 416 ✭✭✭
    edited April 2024
    The way I use Onshape, I generally always want all my documents to be current versions.  Wish there was one box to check, and Onshape would force an update of entire folder (or even a whole project document) instead of having to select each file individually. Especially if those updates happened while offline (is there any way this could be done?). I know what is in all those folders, and I know I want it all updated.
     As I have a large custom library, It takes a lot of time to complete updates manually, whenever I alter content, or Onshape adds new functionality - folder updates could be a big time saver (productivity enhancement). Just a thought - I don't think I'm the only one that would like this (maybe this is the same thing Evan_Reese is saying? - maybe not).
  • chadstoltzfuschadstoltzfus Member, Developers, csevp Posts: 168 PRO
    Short answer is yes. Onshape's API does let you make versions and you could build something that looks at derived/imported parts and update them to the latest version. A version/derived manager that works across documents is something I'd like to build at some point but as it stands that won't be a near future thing.
    chadstoltzfus@premiercb.com
      The "version/derived manager that works across documents" is exactly what I'd like to see in Onshape's core functionalitySo that the "update all" button   (or a separate checkbox) literally updates all (even derived parts coming from outside the current document), not just the items located in the current document.
    A sure fire way to get a doc to update is to trash it then restore it!  >:)
    edited May 2024
    Neil, are you pulling my leg?
  • S1monS1mon Member Posts: 4,069 PRO
    @rick_randall
    No, he is not. It's a bit of a hack, but it does work. It feels scary to do, but until they build some other way to do it, it's the quickest solution.
    Good to know - thanks S1mon
  • darren_13darren_13 Member, Developers Posts: 120 PRO
    Trashing and restoring didn't work for me FYI :/
    I just trashed and restored a document, and branches didn't get updated. Merging with mismatched versions is really really really painful.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,093 PRO
    I think the move might be to delete branch workspaces immediately after they are merged back to main. And if they were never merged, the idea probably died and the workspace can still be deleted. Then there is nothing to update except the Main workspace. Every time I open an old document now I go through its version graph and do this.
    It only takes a day (if you hit the wrong part of the 3 week cycle) for one branch to become out of sync. Then it makes merging much more complicated. And as mentioned in another thread, with workspace protection on it’s even worse. This is quickly becoming a top issue for my company.
    Is this still true for documents with Branches? We're having challenges merging branches. With many people on a team, it's hard to keep people out of a document for a scheduled update that never seems to happen when it says it will, and Trash/Restore didn't seem to do the trick for branches.
  • aeromorrisonaeromorrison Member Posts: 81 PRO
    Yes. I also work with several customers on Onshape data that they own. My team doesn't always have the authority to trash/restore our customer's data to trigger workspace updates. In cases like this it becomes even more convoluted. This happened to me two weeks ago and due to the issues with others accessing, etc. we basically lost a full day working in that document and had to delay an important prototyping milestone.
  • Michael_BillsMichael_Bills Member Posts: 29 PRO
    This is really frustrating. I am completely broken down because the one document I randomly need to work on today is not updated, so I'm just sitting here clicking refresh on my email, hoping someone actually reads my support ticket.
    Why do users not have the option to force an update? I understand why the update goes out on a rolling basis… but if I can't opt out of an update, I need to be able to force an opt in!
  • lanalana Onshape Employees Posts: 761 image
    @Michael_Bills Please tru Hamburger menu/Update workspace.
  • Jan_StegmannJan_Stegmann Member Posts: 5 PRO
    edited September 2025
    I have now tried trashing the document and restoring it. It did not solve the issue.
    This is the second time it happens to us. It is not even an old document in both cases it was the document I was actively working on.
    The first time it happened I just started all over again, as it happened after only 2 hours of work. But now we have a project that cannot move forward and apparently no way to fix it without external help.
    I consider this a very serious issue for a professional tool. At least SolidWorks crashing was something that allowed you to work again after a few minutes, even if it took a hard reset of the computer.
    @Jan_Stegmann Might be missing something, but have you tried this new-ish option?
  • dave_friesendave_friesen Member Posts: 5
    "Update workspace…" worked for me for copying simple shapes that had been throwing an error.
