Linked[in]
Thanks!
Shashank
Indeed, analytical sections would be incredibly useful.
Dries
1. I would like to have the numeric control in the section view.
You can create a mate connector anywhere and use it (instead of a plane) to create a section view. Simply create the mate connector in the assembly or part studio using move to locate it with respect to existing geometry. Select the mate connector then hit the section view tool. You will still be able to use the handles to drag it as well.
What about sketch on the section view? Plane automatically created.
Personally I think these should remain black (or at least have that option as a setting) rather than adopting the part colour as Dries suggests, but the current thin lines (which are actually dotty when they silhouette against white space) definitely make the sectioned face more wraith-like than I would prefer. The cut face should leap out of the page, not retreat into it.
A minor further point: hatching tends to look best when it's roughly midway between horizontal and vertical. At present in Onshape, it seems there is a preference for the opposite tendency: the hatching is often roughly horizontal or vertical. Once again, this reduces the visual impact, and makes the sectioned faces look as if they were produced by some very junior hand.
The attachment below (which shows full size when clicked on) might help illustrate what I'm talking about, when compared with the classy (and punchy) view above, from SpaceClaim.
The hatch spacing is quite random, even for the circular pins which are all the same diameter. It seems to me there should, at minimum, be a consistent relationship between the area of the cut face and the spacing of the hatching.
* (most individual aesthetic considerations are minor, but many small things add up to a big one)
The tool "section view" of SpaceClaim is perfect, it is a great inspiration for Onshape!
Like live planes in SW?
1) Provision of giving some angle or offset value in triad manipulator:-
Now we can freely drag the manipulator to rotate or offset in section. But in most of the cases we need to see the section details precisely in defined areas. e.g. suppose a mate connector is created to see a section view and for some reason I also need to see the section through offset plane at 30 mm distance from initially created mate connector. In this case currently I have to create another mate connector at same distance. Similarly for angular sections I have to create another mate connector at defined angle. So, provision of numeric input will help in this case.
2) Ability to change the angle of hatching lines for every part in section
3) Cross-section measurements such as thickness, radius should be possible in measurement tool
Essential:
- Centroid
- Area
- Moment of inertia (2nd moment of area) about defined coordinate system
- Moment of inertia about principal axes and principal axes angle
- Polar moment of inertia
Nice to haves:
- Torsional Constant
- Shear Center
- Radius of gyration
Presently we have to rotate the manipulator or take the section view from other side...
I'd like the ability to be able to move through the model (normal to section) when the view is normal to the section. Currently there's just the modifier as circle but it does not do anything. E.g.:
- Create a section
- Make the view normal
- Select the section and hover over the input field
- Scroll your mouse (all onshape mouse wheel modifiers work)
That's how to scroll a section in normal view. @_Ðave_ you might like this as well…Thanks
_Ðave_
edit
Shift + 8 is the current quick key, bit of a stretch but might have to start using this.
In some other thread we talked about single hotkey to popup quick-menu near to mouse pointer, that would be brilliant idea for section view trigger too.
