Improvements to Onshape - November 21, 2025
2
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,050 PRO
    @MichaelPascoe What is render cad? an AI image enhancer?
  • Robbie_LillquistRobbie_Lillquist Member Posts: 2 PRO
    From 30 seconds of playing around, Graphics Preferences is awesome!
  • MichaelPascoeMichaelPascoe Member Posts: 2,803 PRO
    edited November 2025
    @john_mcclary Yep, with emphasis on preserving the cad data (geometry, color, design intent).
    I co-developed it with a friend of mine. We are officially launching next week. But I can get beta access for anyone interested.
    RENDERCAD
    That's cool, is it going to be free or limited per/month deals?
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 793 PRO
    @MichaelPascoe you know what's hilarious is I've been experimenting with taking photos of real objects and running them through Nano Banana to make images that look like a CAD viewport because there are good AI models for generating CAD from a screenshot.
  • jelte_steur_infojelte_steur_info Member Posts: 650 PRO
    No more scrolling through long a wide range of columns with (un)suppressed features in a configuration. long live dynamic suppressions!
    (not that this should be applied to multiple parts in a partstudio like this, but this WOW will help with this issue for sure!!!)
    Happy and excited,
    Jelte
    @jelte_steur_info want to clean up my fastener config table now? 😉🤣
    @john_mcclary It will be a monthly sub, new users will get a few free render tokens for testing. Our target audience is professional CAD users who have a need for photorealistic renders.
    There is a link to the pricing page on the main site:
    RENDERCAD
  • MDesignMDesign Member Posts: 1,325 PRO
    Lol that's impressive. Baskin ball? Pumpket ball?
  • Dusan_ChadimDusan_Chadim Member Posts: 1 PRO
    Hi All,
    GRAPHICS PREFERENCES
    Looks fine, long awaited functionality … can be improved by possibility of modify the tangent edges boundary curves as well in same way as the main line witdth.
  • Alex_PittAlex_Pitt Member Posts: 76 PRO
    Thanks for the update. Some great stuff here.
    Love dynamic suppression, drawing view alignment and sketch inferencing!
    Looking forward to exploring AxF in Render Studio.
  • ben_druce929ben_druce929 Member Posts: 5 PRO
    OMG EDIT PERSPECTIVE FTW!!!!!
  • FG_BaasFG_Baas Member Posts: 9 PRO
    Why is nobody mentioning the drawing rotation and alignment?! I have been struggling with this from day one.
    Can I also ask for alignment of drawing views by bottom or top edge? I was working on a patent drawing last week where I had several assembly states of an object able to extend vertically, where views of these states were next to each other on a drawing. In that case I would have liked to allign by bottom edge to keep the 'base' stationary.
    Aligning drawing views could also be done by snapping to other object borders, like we see in office apps right now when moving images. Then they won't be fixed to each other when dragging around, but his way you won't have to add any buttons.
    View rotation has been around for a while, I think they just moved it on the menu.
    I just wish it were persistent. So, when you have a part that's modeled on an angle in the part studio, but want it flat in the drawing. You have to delete all the child views, then re-align vertical/horizontal then re-create and dimension all the child views. I wish it would re-establish the rotation after updating the angle in the part studio.
    Agreed. That's the way I've seen it behave in other CAD packages. It's weird that once you create a child view, the parent view becomes locked and can't rotate anymore.
    Ramon Yip | glassboard.com
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 576 image
    @ry_gb We have a separate improvement for rotating views and forcing the rotation of the dependency chain of other views - or not.
    @jelte_steur_info did you have to set that up per feature or can you batch it?
    you can batch it using folders. But create or remove, not edit the rule that determines the suppression (yet?)
  • chris_barlowchris_barlow Member Posts: 2
    edited December 2025
    EDIT: This only seems to happen on any drawing with an internal or external thread:
    Has anyone else been experiencing problems when exporting DXF files? They will export, but I keep getting errors when trying to open them with a different program… e.g:
    The following error was encountered while reading
    in ARC starting at line 47530:
    Premature end of object
    Invalid or incomplete DXF input -- drawing discarded.
    Try a different different program. No issues opening in AutoCAD or sendcut send
  • sergey_gosergey_go Member Posts: 5
    Технический английский вариант:
    I would like to request that the tolerance numeral height be made slightly smaller than the dimension numeral height.
  • lorenzo_richmondlorenzo_richmond Member Posts: 2
    I am super excited about the iPad AR Scan and Snap feature!
    MOBILE
    SNAP CAD TO REAL GEOMETRY IN AR VIEW
    There is an issue with window selecting too. I submitted a ticket #399958
    When the edge pixel size is changed, it will sometimes select additional edges.
    The first half of the gif is with 0.6px the long edges are being selected even with the blue window select. Changing the line size back to default in the second half of the gif restores the expected behavior for a blue window select.
    So, if anyone is having selection issues, try resetting your graphics preferences until they get this fixed
    good catch. looks like 1.1px and above seem to function ok. 1 and below I seem to get some unwanted selections. Is it also normal for onshape to select edges (or other geometry) that are hidden from view by other geometry when using window selections? I'd expect that on transparent views but not shaded ones. Or am I thinking of a different software?
    Yes, Onshape will select objects within the selection window even if they are behind other surfaces. (Think acad wire frames)
    the ~ key will allow you to cycle through those items under your pointer also.
    SolidWorks would ignore the faces of transparent parts unless you hold shift. Onshape does not do that if color of the part is transparent (the alpha value of the part), but you do have the option to select through transparency when in the "isolate" or "make transparent" modes via a checkbox. SolidWorks has this option globally in the settings somewhere.
  • richard_lewis419richard_lewis419 Member Posts: 2
    Can you please start posting a transcript of your video commentary? It is really hard to figure out if the information you need is going to be contained in the middle of a video. You could do it in an unintrusive expandable box beneath each video, and it would be a huge improvement to the usability and accessibility of the content you produce (both for update info and tutorials).
  • felix_leofelix_leo Member Posts: 5
    Dynamic suppression and the new graphics preferences will be useful in my workflows. The drawing updates and AR snapping also look practical for daily tasks. Thanks for expanding these tools.
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 983 ✭✭✭✭✭
    Has it been 3 weeks since the last update???? Asking for a friend.
    Bryan Lagrange
    Twitter: @BryanLAGdesign
