Auto align view when opening sketch
nicolas_duhamelnicolas_duhamel Member Posts: 7 ✭✭
Hi,
I've looked around but couldn't find a topic on this fonction : is there a way to auto-align the view (i.e. view normal to the sketch plane) when opening a sketch or creating a new sketch?
It's seems obvious, and many other CAD software auto align the view when doing so. But in OnShape, I have to manually click the "views cube" in the top right hand corner.
Thanks for your advices.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,956 image
    edited November 2019
    No, but it has been requested. Vote here: https://forum.onshape.com/discussion/8320/option-to-automatically-view-normal-to-new-sketch
    You can also press N on the keyboard which is currently the way to do it.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,029 PRO
    Agreed, if you do implement that Improvement request auto normal to new sketch, please give the option to turn that crap OFF!
  • yael_PERICARDyael_PERICARD Member Posts: 1 PRO
    Please, make it automatic and make it possible to disable if people don't want. In 2020 we should have the choice, other CAD software have it and it's very convenient !
    I agree this should be a choice. We could argue which is default or not until the cows come home. I'm savvy enough to be able to find and turn that garbage off. So default it on if you want. 🤮
  • michael3424michael3424 Member Posts: 753 ✭✭✭✭
    Alibre auto aligns views on me all the time and it bugs me enough that I'd want Onshape to default to having the feature defaulted off.
  • alec_sarchealec_sarche Member Posts: 2 EDU
    Anyone have any updates on this? Would love to activate a feature like this if it exists
  • MonoAndMaudeMonoAndMaude Member Posts: 4
    +1 for option to auto normal to sketch and, while we're at it, hide planes. These are two keystrokes I need to invoke at beginning of every sketch
  • martin_kopplowmartin_kopplow Member Posts: 1,172 PRO
    I vote for NOT making auto-aligning the sketch view an Onshape default. I see that in other CAD applications and it's getting on my nerves there. I am happy the view (which I have probably purposefully set before) does not change only because I open a sketch edit dialog. I sometimes have to help a friend who is on Fusion, and besides other annoying things Fusion does, it locks the screen to normal all the time when sketching, limiting my view on the geometry behind the sketch, making targeted selection extremely hard to execute and forcing me to unlock normal view all the time.
    I have no issue hitting N now and then, should I actually need it. Please-please no default!
    @MonoAndMaude And as far as auto-hiding planes is concerned: Please don't. Planes are your friend. Use them.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,046 PRO
    Agree with not as a default, and user selectable if it's added as an option. After 20 years of Pro/E that did the auto-normal, and not knowing all the time how it was moving me (especially in the early years where it didn't animate the movement), OS is way better in not moving when taking you to the sketch.
