How to bend a part along a projected curve
jason_ryan337jason_ryan337 Member Posts: 55
Hi all. I would like to bend an ornate column along a projected curve on a curved surface. I have created a simplified column in the document below and would like to bend it onto the face of the bowl behind it. Is there a way this can be done reasonably? I would like to create a much more ornate column so drawing and extruding it directly on the curve face seems really hard.
If this method seems too difficult, could I instead start with an "unwrapped" flat surface of the bowl and add all of the columns to the flattened surface and then wrap the entire assembly back around the bowl (after writing this, it seems to have the same problem, lol)?
https://cad.onshape.com/documents/86202c50e42847587ee33ffd/w/cc0a2b38dd041a0c369d4ae0/e/1e40f934f2c900c897015652
