Arrange tabs in right direction
Hello, When I make a new part studio or drawing it is moving automatically on the end of all tabs. When I want to move it to be on first positions I am able to move it by just dragging it. But after that I am not able to move tabs on the right, I can but only between visible tabs. It is very difficult to arrange my tabs later. Am I right or I am missing something? Thank you!
My tests were run on chromebook&chrome.
I would like to see drag&drop also in hamburger menu which I mostly use for switching between tabs..
https://forum.onshape.com/discussion/1349/multiple-tab-select
I have one workaround for part studio and assembly tab with the help of that you can create tab on required position. For drawing this method is not working.
Step1: Open tab of document in which right side you want to create/place tab.
Step2: Now create new part or assembly studio tab. It will create just right side of previously open tab (Step1).
Step3: If you want to place your tab left side then drag and drop to left as shown in below video.
If user are able to drag & drop tab also in hamburger menu then it will be beneficial for user to arrange tab.
@viru Thanks for the video. I use this method drawing on left, but I have around 100 tabs and when I move fast on left sometimes I skip the place and then... I can't move my drawing on right next to the part studio for example, so I have to drag everything on left again, but 100 tabs are too much.
Thanks everybody! Do I need to send feedback for this?
