Sketches won't loft
brad_shostakbrad_shostak Member Posts: 2
I am trying to get the two faces in my document to loft be each time I try the inner profile just goes red. No idea how to fix this, would really appreciate some help.
https://cad.onshape.com/documents/a029e4e0f14f06e8c8efb638/w/5c0b632cb8f6c2a9d3d007c4/e/e7762b37295653af6d83ecfc
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 954 PRO
    I bet the error you're getting says "cannot use faces or regions with inner loops as profiles."
  • S1monS1mon Member Posts: 4,138 PRO
    You need to do the loft in two steps (outside and inside), or loft the outside and shell it.
