Improvements to Onshape - June 26, 2026
mlaflecheCADmlaflecheCAD Member, Onshape Employees, Developers Posts: 207 image
edited June 26 in New in Onshape
This release brings Asynchronous simulation; submit studies and keep modeling without waiting for results to complete. It also includes improvements to CAD features, rendering tools, manufacturing, and administration.
CAD
ASYNCHRONOUS SIMULATION
A new Results and history table displays all simulation jobs: queued, in-progress, and complete. Submit studies while modeling. Jobs run independently without blocking your work. Results are stored permanently in version control history with full logging of conditions and outcomes for traceability. See the new Asynchronous Simulation topic in the Onshape Help for more information.
https://onshape.wistia.com/medias/lzk6om8b4d/
DERIVED PROPERTIES
Onshape has updated the behavior of the derived geometry feature's properties checkbox. Previously, this setting was always enabled when creating derived features, automatically including all properties like part numbers and manufacturing processes from the original source. Now, the setting has become sticky - when disabled, it remains unchecked for future derived features until manually re-enabled. This improvement helps users avoid accidentally reusing part numbers or copying incorrect property values like manufacturing processes.
https://onshape.wistia.com/medias/7sjh6ikhi0/
ACTIVE COMMAND HIGHLIGHTING
Toolbar buttons now appear active while a feature is in use.
https://onshape.wistia.com/medias/nzkca2x2g1
DRAWINGS
PARTS ONLY DEFAULT VIEW STYLES
Previously, templates would automatically insert annotations like centermarks and centerlines for both parts and assemblies. The update makes these settings exclusive to parts, where they are more useful. This improvement allows users to keep annotations enabled for parts, where they're beneficial, while creating cleaner assembly drawings.
https://onshape.wistia.com/medias/vi1q2qgd56/
RENDER STUDIO ADVANCED
CAMERA GAZE DIRECTION INDICATOR
Render Studio now includes a camera gaze direction indicator in the environment lighting editor, making it easier to orient environment lighting relative to the camera for more accurate and predictable rendering setups.  Also, physical lights and volumes can be duplicated.
https://onshape.wistia.com/medias/r7hra3dw9e/
CAM STUDIO
'CREATE MACHINE' DIALOG MODERNIZATION
This update announces improvements to Onshape's CAM (Computer-Aided Manufacturing) user interface, specifically focusing on machine creation functionality. Building on previous UI updates that enhanced job creation, setup creation, and work plane creation dialog, the latest release extends these improvements to machine creation. The goal is to create a more consistent and familiar user experience by aligning the CAM interface more closely with the broader Onshape UI design language.
https://onshape.wistia.com/medias/fcgvt78ff2/
GENERIC DATRON POST PROCESSOR
A new generic Datron post processor is now available out of the box. Shops running Datron machines can get started without creating a custom post processor from scratch.
IMPORT/EXPORT
GLB FORMAT TRANSLATION
GLB format translation is now integrated into Onshape, expanding interoperability for visualization, XR, AR, and VR pipelines.
https://onshape.wistia.com/medias/77f8jy2bqg/
ENTERPRISE
Improvements to the company user list for all Enterprise level accounts (Onshape Enterprise, Onshape Government, Education Enterprise) help admins more efficiently manage large user bases and cohort rosters.
https://onshape.wistia.com/medias/dftfdb7lb2/
Remember: The updates listed here are now live for all users when creating new Documents. Over the next few days, these features will also be available in Documents created before this update. Mobile app interface updates occur via the Apple App store or Google Play store and happen in the days following the update.
Regards,
Mike LaFleche   @mlaflecheCAD
  • S1monS1mon Member Posts: 4,346 PRO
    Asynchronous simulation with stored results should make simulation much more manageable.
    Lots of other useful quality of life improvements.
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 1,038 PRO
    edited June 26
    I'm going to take the improvement to include part properties via Derive operations as first party approval of my Amalgam shenanigans. Maybe now I can start making real BOMs for my drawings again instead of dumping to an external table to sort things out.
    Edit: oh and we got .GLB format support! Thanks @lougallo and team for getting that plugged in for us.
    Just noticed “Improved quality of boundary surface from curves” in the change log. Any more details on this?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 6,078 image
    There is more to come on this, so stay tuned. Just be assured that boundary surfaces are better quality than before.
    I also see some new sheet metal functionality creeping into the logs. Looking forward to all of the new unintended use cases these might enable.
    In the spirit of hidden updates… a little birdie just told me to look at opFitSpline.
    https://cad.onshape.com/FsDoc/library.html#opFitSpline-Context-Id-map
  • aeromorrisonaeromorrison Member Posts: 87 PRO
    Great release! I'm going to love asynchronous simulation and sticky derived part properties checkbox.
    That was in the last release, but we forgot to document it 😯
  • antonio_mattanaantonio_mattana Member Posts: 2
    TypeError: this.scalarVisualizationOccurrenceIdsByPath.keys(...).toArray is not a function.
  • MDesignMDesign Member Posts: 1,451 PRO
    Active command highlighting is a nice one. Looking forward to the day where I don't have to scan all the tools to find the one I need… via colored tools or something to help the eyes gravitate and be more efficient. at guiding the mouse to the intended target.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,245 PRO
    Thanks for getting rid of auto center-marks (or giving us the option anyway)!!!! I haven't used them since 1996:) It was always a pain clicking on ever single view I made and turning them off the past 5 years. IDK if that was in this release, or a prior one and I missed it.
  • christopher_dziubachristopher_dziuba Member Posts: 124 ✭✭✭
    Those auto-center marks have been pretty annoying! Glad to see them optional now. And VR file type compatibility is really getting me excited!!
  • volodymyr_biliakovvolodymyr_biliakov Member Posts: 3 EDU
    Help! After the last update, the variable table disappeared, drawings do not open, I cannot change drawings. I tried restarting, changing the browser, clearing the cache, nothing helps.
  • Paul_J_PremakumarPaul_J_Premakumar Member, Onshape Employees Posts: 236 image
    Thanks, I sent it but they are still silent, I thought maybe someone had something similar. I tried on another computer (although the OS, system and settings are the same) but nothing works. There was some update on 06/26/26 after which such a problem occurred.
  • EvanReeseEvanReese Member, Mentor Posts: 3,002 PRO
    Yeah this one was from the target length addition to Routing Curve last release, but I love that it's just part of opFitSpline now!
    Thank you, everything is restored.
    edited June 30
    Nice improvement to simulation too! I only did one design simulation when it first came out, and I think I took screenshots of the results for 5 different options since it could only show the latest at that time.
    @Nick_Holzem @NeilCooke
    In order to see the improvement in Boundary surface, I assume that the feature needs to be recreated?
  • Nick_HolzemNick_Holzem Member Posts: 238 PRO
    @S1mon yes, I needed to use a new boundary surface.
  • billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,157 PRO
    asynchronous simulation is fantastic and now I don't have to take screenshots trying to remember the old analytical methods I used.
    I would like better representation for conditions like materials, loads and what was fixed. From the screen graphics you can't really tell what's going on, how much force?. Even just a note field so I could type in why & what I did and the assumptions that I made would be a big improvement trying to recall what happened. When you're creating a report and screen capturing, you have to type notes explaining what's going on which is detached from the analysis but should be part of the analysis. It would be nice if this was captured for future reference.
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 1,027 ✭✭✭✭✭
    @john_mcclary break out the bingo cards. It is officially F5 Friday
    Bryan Lagrange
    Twitter: @BryanLAGdesign
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,088 PRO
    Whooo Hooo!
