Can't chamfer an edge
henry_feldman
Member Posts: 134 EDU
So this may be stupidity (or OnShape noobness) on my part, but I can't chamfer an edge in the image below; all the other edges took a chamfer or fillet as needed. There is no error that I can see, and sometimes it shows a preview briefly of a chamfer or fillet (I tried both) but it goes away shortly after appearing. I don't know if this is due to a constraint (that bar going towards the bottom is constrained to coincident to the right edge of the object). I have made the document public and it is called "Sternal Retractor - debug".
viru
Member, Developers Posts: 619 ✭✭✭✭
@henry_feldman , You can give either 5 mm fillet or 1 mm chamfer in your model. I found below observation in your model.
1) If you want to keep chamfer = 1 mm then you can give fillet value maximum upto 4.6 mm in your model.
2) If you want to keep fillet = 5 mm then you can give chamfer value maximum upto 0.93 mm in your model.
3) If you want to achieve your requirement fillet = 5 mm and chamfer = 1 mm then you have to apply chamfer before than fillet on your model as shown in below video.
Kindly refer below video for more detail.
5
