how do you change the dimension
I'm new to this, when I put in a dimension line, the box comes up so you can change the length. When I change the length nothing it happens. I can type the new number in but then it doesn't change the drawing. What am I doing wrong... frustrating start!
  • øyvind_kaurstadøyvind_kaurstad Member Posts: 234 ✭✭✭
    edited January 2016
    After inputting the new length, you press enter and then nothing happens? And your sketch doesn't go red to show that you are trying to over-constrain it?
  • Narayan_KNarayan_K Member Posts: 379 ✭✭✭
    @ lucy_coleridge  , Refresh your browser and try it again.
    edited January 2016
    @lucy_coleridge , Kindly press " Enter "  from keyboard after putting new value as suggested by kaurstad
    Kindly refer below video for more detail.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,929 image
    Hi Lucy, you are probably seeing the "scale sketch with first dimension" feature, where all sketch entities scale by the same amount to prevent the sketch from turning into spaghetti. Subsequent dimensions will modify the sketch as you expect.
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016 image
    If the dimension is not changing when you hit Enter, this was a common problem when using Internet Explorer or Edge. Please go to cad.onshape.com/check to make sure you are using a supported browser.
