Improvements to FeatureScript - January 26, 2016
lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
edited January 2016 in FeatureScript
The latest set of improvements to Onshape also includes several FeatureScript improvements:
  1. Improved documentation, including a tutorial that walks you through making a feature: https://cad.onshape.com/FsDoc/tutorials/create-a-slot-feature.html.
  2. Go to definition: Ctrl+click (or Command-click on a Mac) on a function name to navigate to where the function is defined.
  3. Autocompletion: as you type, available functions are suggested.
  4. A new function evDistance for computing distances between parts, faces, points, etc.: https://cad.onshape.com/FsDoc/library.html#evDistance-Context-map
    FS Examples has been shared with you View Only.  Have fun writing features and we look forward to seeing what you can build and remember you can share within this forum category if you like!
~ Team Onshape
