Improvements to FeatureScript - January 26, 2016
lougallo
Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016
The latest set of improvements to Onshape also includes several FeatureScript improvements:
Improved documentation, including a tutorial that walks you through making a feature: https://cad.onshape.com/FsDoc/tutorials/create-a-slot-feature.html.
Go to definition: Ctrl+click (or Command-click on a Mac) on a function name to navigate to where the function is defined.
Autocompletion: as you type, available functions are suggested.
A new function evDistance for computing distances between parts, faces, points, etc.: https://cad.onshape.com/FsDoc/library.html#evDistance-Context-map
FS Examples has been shared with you View Only. Have fun writing features and we look forward to seeing what you can build and remember you can share within this forum category if you like!
I am glad to see that the improvements also are implemented in Featurescript
The link "FS Examples" isn't working for me.
https://cad.onshape.com/documents/56a83c42e4b0844ecdcfb352/w/4bea5dd5fc766e7cb238167a/e/7d15f8bc8f233255fcbd9e87
either the document has been removed or I don't have access.
