Is there a way to send multiple screen shots for feedback?
knuckledraggerknuckledragger OS Professional Posts: 9
I had an issue that would have been more clearly explained with a before and after screen shot was curious if there was a way to do that.   Not sure if we could create multiple screen captures or hit a short record button to demonstrate the issue more clearly.
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
    @Knuckledragger You can.  Once you do the first screenshot, you can use your own captures and attach them to the email you receive on the first one.  I have looked at having a video record feature, which is supported but I have turned it off due to it requiring a plugin to work.  It is not cross platform and makes the support experience different for each user.  So far with well over 1000 tickets, the markup in addition to the description is more than enough in most cases.  We will be making it very easy to share the document with support in the next week or so and that is the ultimate understanding of the issues.
  • john_rousseaujohn_rousseau Member, Onshape Employees, Developers Posts: 421 image
    Hi @Knuckledragger. In the "?" menu on the upper-right of the screen you can select "Feedback". That will put you in a mode where you can send a message and take a screen capture at the same time. Let me or @LouGallo know if you have any problems reporting your issue.
    -John
