lock two parts together
arturs_ziprisarturs_zipris OS Professional Posts: 27 PRO
Can I lock two parts together as they are standing, without defining a special mate. Group would work just fine, but my two parts are in subassembly and group will not work in top level assembly causing me headache again.
  • raj_Onshaperaj_Onshape Onshape Employees Posts: 111
    If two parts are grouped in a subassembly, their relative position should be the same in all top level assemblies they are included. If it is not the case it should be reported as a bug.  Could you please share a sample where it is not the case ?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,866
    Open the subassembly tab and group them in there
  • arturs_ziprisarturs_zipris OS Professional Posts: 27 PRO
    Thanks a lot - it helped!
