remove public documents
donald_8donald_8 Member Posts: 40 ✭✭
how do i remove public documents from my list. i looked at a few and now they are lists in my documents. i would like to remove them
    They are actually listed in "recently open", If you select "my documents" just below they won't be listed.
    _Dave_
  • donald_8donald_8 Member Posts: 40 ✭✭
    thank you.
    I did know that, and do that all the time. i just wanted to remove them from my list, so that's why i asked how to remove them. maybe i can't
  • paul_1paul_1 Member Posts: 33 ✭✭
    i agree -- it's annoying that documents i looked at by chance some time ago keep showing up in my list.  a "forget" command would be nice, if just for uncluttering reasons.
  • brian_jordanbrian_jordan Member, Developers Posts: 144 ✭✭✭
    edited September 2016
    It seems that a redefinition of "recent" would fix this; maybe ideally a user configurable option so anyone wanting to keep long lists would also be catered for.
  • evan_morrisevan_morris Member Posts: 2
    Once you delete a public document, is it completely gone from ONSHAPE's Public Database?  Or does it linger, somewhere.  The reason I ask is because I need to delete a project that was not intended to be public.  I deleted it from my account, but I was not sure if it still existed somewhere in the ONSHAPE, shared, Public Database.
    @donald_8
    @paul_1
    You can right-click on a document in recently opened and choose remove from recently opened
  • bob_bobcatbob_bobcat Member Posts: 2
    Hi Evan  / Neil
    I deleted an upload within 5 minutes of uploading. It was may personal design and I did not want it public.  I searched and  noticed the document has an owner name now next to it and is  " main in progress".  Does this mean someone took ownership of my design within and I have lost all copyrights to it?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,927 image
    Hi Evan  / Neil
    Quite possibly - the document you found - it is the same thing you uploaded? Is it read-only (and therefore belongs to somebody else)?
