Lost my progress.
fropfrop Member Posts: 9
So.. I had enough of my part outlined in a 2d sketch to have a grey line shade everything in. Later I went to add a midpoint of what would be a circle and next thing i know I am back to what things looked like last time I started using the software (which was in the morning. I used it in the morning then stopped and started my task at night again). So... has anyone else had this problem? I have a screen shot of my work before this happened then after. I thought onshape kept a record of everything you did on a project so you could undo anything. The undo and redo buttons aren't available =/
    Undo/redo is only available for current session (Onshape timeouts in 20 minutes if not in use).
    History is recorded though and you can go back between accepted edits.
    One of the mods I think helped me out. Seems like I was doing a sketch and somehow hit cancel so it lost all what I was doing. Can't recover a canceled sketch =/
    viruviru Member, Developers Posts: 619 ✭✭✭✭
    @frop ,Currently user cannot recover canceled sketch entity in Onshape. You can raise improvement request for this. In near future we hope that this facility will be provided by Onshape.
    lougallolougallo Member, Moderator, Onshape Employees, Developers Posts: 2,002
    @frop  That is correct.  If you hit cancel and have not committed that active sketch, you cannot undo this.  We are aware of the issue and are working on a solution so that is captured in the history.
