Lost my progress.
frop
Member Posts: 9 ✭
So.. I had enough of my part outlined in a 2d sketch to have a grey line shade everything in. Later I went to add a midpoint of what would be a circle and next thing i know I am back to what things looked like last time I started using the software (which was in the morning. I used it in the morning then stopped and started my task at night again). So... has anyone else had this problem? I have a screen shot of my work before this happened then after. I thought onshape kept a record of everything you did on a project so you could undo anything. The undo and redo buttons aren't available =/
History is recorded though and you can go back between accepted edits.
