What can I do to speed up Onshape?
bill_daniels
Member Posts: 277 ✭✭✭
I have a Dell T3400 Precision workstation running Ubuntu 14.04 with a 12MB/sec internet connection. I've tried several browsers and made sure webGL was operating.
Onshape runs so slow on my system that I can't really do any serious work. Why is that and what can I do about it?
I think it's best for you to send feedback to Onshape using the ?-mark menu in cad. Support can take a look at your particular case.
That said, offering a guess without knowing anything more than what you described in your setup, perhaps you don't have NVIDIA drivers installed for your video card (or webgl is not using them) and are falling back to software rendering (excruciatingly slow). If, say in Google Chrome, you look at the output of chrome://gpu you should see something about NVIDIA in the GL_VENDOR or GL_RENDERER fields of the Driver Information table.
All of that said, the T3400 is an 8 year old system I think and even properly configured may not provide the best performance.
It runs nVidia driver 9.18.13.4084, and seems to run Onshape modeller pretty well, but drawings are very slow indeed
Here's the problems and workarounds reported after pasting chrome://gpu in as the browser URL:
Graphics Features disabled
Driver Bug Workarounds
(NVIDIA drivers before 337 lack features in NV_path_rendering and related extensions to implement driver level path rendering)
It would be good to know if any of these are likely to make it a losing proposition to run Onshape, and if so, which
I have a public model called Volta 2D 300 you can look at.
https://www.khronos.org/registry/webgl/sdk/tests/webgl-conformance-tests.html
WebGL Conformance Test Results
https://forum.onshape.com/discussion/comment/10822#Comment_10822
Another thought... upgrade the graphics card?
There are lots of newer Quadro cards on eBay and I'm wondering if it's worth buying one. My T3400 has 8GB of memeroy and the T3400 can use 16GB so an upgrade there is a possibility but DDR2 memory is expensive. The money might be better spent trading up to something like a T7500
So, why is that? Perhaps a workstation video card doesn't support WebGL the way a consumer video card does. Or, maybe, it's just older workstations cards that have an issue with WebGL. Maybe it's that all the BB machines were running Windows and I run Ubuntu Linux.
If I were you, I'd contemplate purchasing all new hardware rather than patching up what is an older machine now. But, I don't know your budget or your reasons for your setup and what you are doing with it.
Not sure why this is, any mac/linux users experiencing the same thing?
