Can ANSI holes be exported to STL?
Jlabs
Member Posts: 28 ✭✭
I've created a test plate with 1/4in 20 through holes and selected "tapped". When I view the STL file the holes
NeilCooke
Moderator, Onshape Employees Posts: 5,927
By specifying a tapped hole, Onshape is calculating the drill size and applying that to the model. If you want the actual thread for 3D printing then you will have to model it yourself using a helix and a sweep.Senior Director, Technical Services, EMEA5
