How do I move an object?
Newbie here with a simple yet stupid question.
How do I move an object? thanks,
Transform adjusts a part's location and orientation in 3D space with the option to copy the part in place.
- Make changes to one part and use both to create different bodies during a later operation.
- Make a copy of a part prior to a series of operations enabling you to reference the original state for ancillary operations.
- Create multiple copies of a part in order to create multiple variants.
If you need to create multiple copies of a part at once, use the Pattern feature with a distance of 0 (zero).
Before translate by line
After translate by line
Before translate by distance
After translate by distance
Before translate by XYZ
After translate by XYZ with copy part option checked
Before transform by mate connectors
After transform by mate connectors
Before rotate
After rotate
Transform adjusts a sketch's location and orientation.
Steps
Tips
Thank you for the response. But what I want to know is how do I move or copy A single entity or multiple entities In a specific X Y Z dimensional direction in sketch mode. Example how would I move a horizontal line within a rectangle .250 in the Y direction in sketch mode. The transform command in sketch mode does not give you the dialog box to choose the method ( Translate by line,Translate by distance,Translate by xyz,,,,) like the transform option the the main tool bar. this I do not understand.
Thank you I will try using that frame of mind in the future.
