How do I move an object?
https://forum.onshape.com/discussion/4021/how-do-i-move-an-object#latest
Transform adjusts a part's location and orientation in 3D space with the option to copy the part in place.
- Make changes to one part and use both to create different bodies during a later operation.
- Make a copy of a part prior to a series of operations enabling you to reference the original state for ancillary operations.
- Create multiple copies of a part in order to create multiple variants.
If you need to create multiple copies of a part at once, use the Pattern feature with a distance of 0 (zero).
Before transform by mate connectors
After transform by mate connectors
Before rotate
After rotate
Before copy in place
After copy in place
Before scale uniformly
After scale uniformly
