Import DXF fill issue
shai_perednik
Member Posts: 56 ✭✭
I'm trying to import a DFX of a logo that I saved out of inkscape as a DXF. I then want to remove this shape from the part under it. However, as you see in the image below, the dxf imports as the outside paths only, therefore, its only the outline that I can extrude/remove. This is not what I want as I want the fill to be used for the extrude/remove.
Am I importing the DXF wrong, or do I need to do something else here? Thank you!
ml
Member Posts: 53 PRO
have had the same problem once with an imported dxf. the reason was that not all endpoints matched to the next - so no closed loop @jackson_king
alread mentioned. selecting the endpoints and made them coincident fixed it in my case5
