Onshape mobile performance/Limitation
mark_biasottimark_biasotti Member Posts: 123 ✭✭✭
Has anyone else noticed when Onshape is running on the iPad or iPhone that when loading a large model, it loads the model (and takes a long time to load) but then it finally loads, abruptly quits. This occurs for me on my iPad when loading the Porsche Model (which is public.)  Does the iPad run out of video memory?
  • joe_dunnejoe_dunne Onshape Employees, Developers, csevp Posts: 198 image
    it loads for me
    My guess is you need to update your build. We are routinely updating that application. are you on 1.16.8?
    did you get a update notice via email ?:
    Joe Dunne / Onshape, Inc.
  • mark_biasottimark_biasotti Member Posts: 123 ✭✭✭
    Hi Joe,
    I did update "TestFlight" (or whatever it is called) just yesterday. Do you think I need to restart my iPad. Could it be the type of iPad I have - mine is a couple of years old?
    edited February 2015
    mbiasotti said:
    Hi Joe,
    Mark, Onshape is very noticeably faster/snappier on my new iPad Air 2 vs iPad 3 (2012). Although since the last few updates, the performance gap has diminished. Especially when rotating the model when geometry is selected.
    btw, You need to update the Onshape app from WITHIN testflight.
    Dries
  • mike_mortonmike_morton Onshape Employees Posts: 1 image
    Mark, I don’t know of any changes in the iOS client which will help you load large models. I suspect the limitation is total RAM, not video RAM, but can’t be sure.
    How much RAM does your iPad have? (See http://en.wikipedia.org/wiki/List_of_iOS_devices#iPad or maybe the Settings app tells you.)
    Restarting your device is always worth a try, but I wouldn’t expect it to help. Updating the app is always a good idea — we want you to have the latest and greatest. But we certainly need to improve our handling of large models.
    Where do you go to upgrade OS on the iPad?  (I have upgraded Testflight already)
    Mine just does it, can't say I've ever had to update it.
  • rbaekrbaek Moderator, Onshape Employees, Developers Posts: 77 image
    mbiasotti said: Where do you go to upgrade OS on the iPad?  (I have upgraded Testflight already)
    Hi Mark, you can currently download updates for Onshape on iOS via the TestFlight app.
    In order to download updates, you must be added as a tester. If you already are a tester, make sure you are signed in with the Apple ID that was added as a tester.
    If there aren't any updates, then you may already have the latest build. To do a quick check, you can compare what is currently on TestFlight (1.16.8) and what is on your device. You can check your build on your device by signing in, and tapping on the profile icon on the top right. On the bottom left of your profile, you will see the current build number on your device.
    The current process will be temporary and we will switch to updating via the App Store in the near future.
  • john_f_carrjohn_f_carr Onshape Employees Posts: 74 image
    The Porsche model also made webgl clients unhappy.  We fixed that last month.
    We're not quite to sports car weather here in Massachusetts yet, but I can already see the snow piles starting to give up the fight.
    @ baek
    Thanks got it. I
    currently have 1.16.8.
    Unfortunately, still when I load my Porsche model it loads but if I try to spin it, it crashes OS.
    @John_F_Carr
    Yes, I empathize with all of you back there with 7' drifts in your front yard... Did I tell you it is 76 Deg. here in CA... and boring weather!
    Mark
  • ilya_mirmanilya_mirman Member Posts: 24 ✭✭
    @mbiasotti  - our snow is cloud-native.
  • jon_hirschtickjon_hirschtick Onshape Employees Posts: 91 image
    edited March 2015
    @Ilya Mirman Full-cloud
    Even in onshape beta I am still having an issue with this. I'm not complaining but just want development to know that the problem I originally posted still persists on my iPad mini. I would send a bug report but OS crashes with any screen interaction just after loading the porsche.
    mark
    mark
    Hi Mark,
    Which iPad mini model are you using? The latest iPad mini 3 would be most optimal to use Onshape, but the earlier models should be compatible for using Onshape as well.
    Do you have other iOS devices to try? Are you able to open the same model on other iOS devices?
    (rbaek - would like to know your full name so I can address you properly)
    I'm not sure but I think it is a mini-2. It is actually my wife (for me to use... you know how that goes) and will check when I get home tonight.
    Mark
    @rbaek. My iPad is: Model  A1432 (printed on outside back)
    From settings>general>about:  capacity 12.7G 7.4G available version 8.1.2 Model MD531LL/A
    That model should work fine. Your mentioning of the document loading but abruptly quitting sound more or less like a memory issue. Do you remember if you were running any apps in the background?
  • JPC204JPC204 Member, Developers Posts: 8
    hi mark, sorry to jack your thread. in addition to mark's porsche model, are there any other large assemblies available for viewing? I think Jon had a spaceship in his presentation but I can't seem to find it in the tutorials or public models. But maybe I'm using the wrong search query?
    i did note that the CPU on my system did a decent amount of work opening Mark's porsche model. average about 20% of my quad core 2.4ghz.
    I'm having same issue with the porsche model, Ipad2 model A1430
    But I was amazed that OS even worked in such old device.. Simple models run very smoothly.
    There's a collection of Tutorials and Samples that are of decent size. Are you looking for something larger?
    For the iPad 2 and the 1st gen iPad mini, the maximum RAM for both devices is 512MB, with the available RAM being much less. We do our best to control memory usage within our app, but you have any apps running in the background, it may affect your ability to view larger documents. With the newer devices that have >1GB of RAM, we have tested and verified that the general experience is much smoother and can handle much larger documents than devices with 512 MB.
    We have implemented some optimizations such that the experience will not be much different between newer and older devices, but the RAM limit is something that will affect which documents you may open and view, and it is an obstacle we are continuously trying to resolve.
    I think it would be a shame to wholesale adopt OS as the accepted abbreviation of Onshape
    Mark Biasotti asked, further up this thread, "How do I update OS on the iPad"
    OS is clearly already taken.
    Operating System is abbreviated to OS by long-standing convention.
    Situations could easily arise where it's not exactly clear what is being asked or said.
    It will also rule out meaningful searches on the web.
    I would like to suggest OnS as a better alternative abbreviation for Onshape.
    (pronounced "On-Ess").
    @Andrew_Troup You have a good point there with the web search, once tried to make a search for video codec software called g-spot ;)
    You should propably make a new discussion to get everyone in - I will follow OnS
  • daryntaylordaryntaylor OS Professional Posts: 31 ✭✭
    Good Idea, I agree that OnS is better.
    rbaek, i'm looking for the most massive!
  • jared_conwayjared_conway Member, Developers Posts: 2
    @mark_biasotti
    would you be willing to share that model?
    would love to try onshape with some bigger models! thanks!
    @mark_biasotti
    It's already shared in the public area, at
    https://cad.onshape.com/documents/9c9e7c3a1bad46a7973bffc3/w/a80a49e01f88472b854c8ecf
