Spur gear script OK?
risto_alanko
Member Posts: 3 ✭
I tested the spur gear script, I'm planning to print a gimmick gear train in 3D. Is the script working OK with large numbers of teeth? The shape of the gear flanks seem s OK, but the gap between the teeth is strangely deep and the fillets disappear on around 100 teeth .
I tested a gear pair with module 2 mm, number of teeth 20 and 80, with the theoretical center distance of 100 mm they seem to mesh OK, but the teeth of the large gear are too deep and the fillets are tiny.
Don't forget as well that these are theoretically perfect and 3D printers are quite rough so you may have to modify the module slightly on one gear to introduce some backlash (or move the gears further apart).
My gears will be quite small, the whole gadget will be hand cranked. I'll try to adjust my thinking if I can.
There is something inherently wrong with the Spur Gear Feature Script.
Increasing the number of teeth to large numbers should approach a involute rack.
Here is a link to a 144 tooth gear: http://geargenerator.com/#200,200,100,6,0,1,0,2,1,18,3,6,20,-60,0,0,144,24,6,20,-60,0,0,2,781
Compare that to your result for a 144 tooth gear. Something is not right with the Script.
Please feel free to contact me if you would like to collaborate on getting this Script fixed so that it produces correct results.
Thank you.
Joe
A search for gear whole depth led to several versions
http://khkgears.net/gear-knowledge/gear-technical-reference/calculation-gear-dimensions/
http://www.micro-machine-shop.com/module_gear_data.pdf
http://www.engineersedge.com/gear_formula.htm
The formula varies from 2.157 to 2,25 times the module for whole depth. With large numbers of teeth say 100 the whole depth is clearly too large as shown in the visual example in this thread.
I see the offset can be used to correct this but it would be very handy if the zero setting was set to a given formula.
Thanks
Dan
https://forum.onshape.com/discussion/6179/updates-to-spur-gear-feature/p1?new=1
