Onshape BOM Google Sheets no Update either direction
jochen333
OS Professional Posts: 28 PRO
Hello
I tried all the current possibilities in Onshape for BOM creation and maintenance.
For now i like the Lou Gallo app Onshape BOM the most, because OpenBOM feels like early beta and still needs features.
But there is one problem: I coulnt achieve an update in either direction.
If i change some properties in part studio the Sheet is not updated and if i change something in the Sheet the prperties in part studio are not updated too.
Does anyboday have an idea or got this to work already?
Update: Of course i tried the "Update metadata" all the time
To push the Google sheet changes back to Onshape you can us the update metadata. Generally works OK for me.
Once setup I then make all changes to the sheet and push back rather than pull from Onshape.
Of course i did the "Update metadata" all the time i tried the process. Thats the option to bring the updated data back to the onshape parts, or?
I send you a Help request through the Addon in Google Sheets now, wasn´t aware of that Butten in help.
Edit:
Is it not working because right now i am working in a branch?
