Both original edge and chamfered edge shown at the same time ?
Novice:
I have a conical shape made with a "Revolve -> Surface" and then "Thicken" the surface.
Now I want to chamfer (or fillet) the edges coming from the "Thicken".
Now the Chamfer works, but the original surface still remains. Is that a bug, or did I make the conical shape in the wrong way ?
Zoom in on "Chamfer 1" and you should be able to see it.
https://cad.onshape.com/documents/250f16ea2b0e443a3b7fc710/w/30c880181a202ce91b5fe4c6/e/a3e8bb37e13be2969a1b08ed
Thanks in advance, Bo Andersen.
mahir Member, Developers Posts: 1,316 ✭✭✭✭✭
Thickening the surface doesn't get rid of it. The surface body remains. You just have to hide it.5 -
NeilCooke Moderator, Onshape Employees Posts: 5,878
Surfaces are never "consumed" when creating other features from them - go to the parts list bottom left, expand the surfaces folder and hide the surface using the eye icon. You should also consider if using a surface is the correct way to design your part rather than using offset in the sketch to achieve the same result.Senior Director, Technical Services, EMEA5
