View only link on iPhone has issues?
OpenR2OpenR2 OS Professional Posts: 188 ✭✭✭
Has anyone else seen this on the iPhone?
https://cad.onshape.com/documents/31cb79530e830254b7c4661a
I was really excited to share this with the replica prop forum but it doesn look like its working?
  • rbaekrbaek Moderator, Onshape Employees, Developers Posts: 77
    Do you have the Onshape app installed on your device? It appears that you're trying to view Onshape on a native mobile browser, which isn't fully supported.
  • OpenR2OpenR2 OS Professional Posts: 188 ✭✭✭
    I do have the app installed but when I go into email and click on the link I would send to other people it launches the browser ... not the app.
    edited April 2016
    @OpenR2 We are working on creating an "Open in" action for mobile for any links.  We do not support viewing in mobile browsers...   CORRECTION - This does work if you are using Safari. You should see this:
    NOTE: This will require Safari and Javascript to be ON:
    ** Settings -> Safari -> Advanced -> Javascript.. Turn this on! **
    There is in my mind a huge problem with shared links in this version of Onshape.
    I cut and paste a view only link into an email, social media, or a website.
    I click the link.
    The link is by default started in Microsoft Edge on Windows 10.
    No message about the browser being unsupported.
    The first tab is a PDF containing the terms of use ... which just spins.
    So after a few seconds I just click on a part studio tab without reading the terms of use.
    This is VERY bad.
    When I test an email containing a shared link on an iPhone ... I don't get launched into the Onshape app.
    Instead the link is launched into the safari browser.
    I was really excited with the idea of view only sharing but its not working out so well for us in practice.
    Are other people seeing this behavior?
    https://cad.onshape.com/documents/2fdf544ca7208918cf880dd5/w/321f5a8bcf442ce8576904d7/e/5603afc0d86616b2fedec135
    1t get the link launched into the
    I had the same experience with the sharable link. The model just dons't seem to render on safari, at time I was expecting the app to open and was surprised I got anything from the safari browser.
    @OpenR2 There is an underlying issue when you first click on a link that does an Open in prompt.  On iOS if you ever dismiss this, it is not able to come back.  This has been logged as a bug with Apple and there is not solution yet.  We are hoping to get more information at this year's dev conference.
    Any updates on this front? I use Outlook and Chrome on iOS, and workspace links still don't work. Improvement request?
