Modifying Imported Models
Bluchip
Member Posts: 18 ✭✭
I am a newb at this so keep it basic! I successfully imported a STP file and the model appears to have successfully translated. I did not create the model but it was requested that an internal (concave) fillet be increased. It is the highlighted faces on the screen grab below. I cannot seem to come up with a direct way about this.
I am certain most here can manage this with ease and elegance! How should a novice as me go about this?
I have nearly worn that function out!
I simply get the red notation show below when clicking green check.
Perhaps I've not imported/translated correctly?
Or... Can you share the link to the geometry? Perhaps one of us can take a stab at it...
Linked[in]
mentioned there are some tight places in your model that might require more stabbing than direct editing tools are prepared for.
@fastwayjim
Will this work?
https://cad.onshape.com/documents/6afc4cea3304251060dfa79a/w/1e5c589ffc3f7f23bb4552e4/e/d8ad4ec22750270b773944c8
To recapitulate: We are trying to increase the fillet highlighted in below grab. It is currently some .016" and we'd like to go to perhaps .110" and of course, dress up all the little blends at the fillet terminations.
Can you make the document public? I tried to go in and see what I could do, but it is in view only and we can't even make a copy of it.
It is public now.
Yes, I will try and find some time today to dive in to it.
Choosing only the concave fillet will not give you your desired results as shown
All I had to do is select some on the convex fillets to get the (assumed) desired result.
Besides, the result you got is undesirable: Only the concave rads are to be increased.
