Showing Welds in an assembly drawing
rick_chapmanrick_chapman Member Posts: 24 PRO
Is there a method of adding welds to an assembly drawing?  It would be helpful once multiple parts are joined to have the ability to show this.
Thanks,
  • brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,146 PRO
    Do mean symbols on drawings or 3d model weld's?
  • rick_chapmanrick_chapman Member Posts: 24 PRO
    I was looking for them on the 3d models for for an accurate visual representation.
  • wayne_jayeswayne_jayes Member Posts: 13 ✭✭
    I would like t be able to easily and simply insert welding symbols on the drawing
    Wayne, were you ever able to find a method of adding either weld symbols to the drawing or adding to the assembly drawing?
    @rick_chapman I believe they are working on it. Any updates weld details @pete_yodis ?
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 558
    @brucebartlett Yes, weld symbols are needed and important.  We completely understand.
    For a complete hack of a workaround to help get a drawing out the door, you could insert an image of the weld specification you want into the drawing.  Sometimes in weldment drawings, there are not a great deal of variances in the welds specified - so it's possible this solution could be of help while you wait for the real solution in the meantime.
  • michael_hassonmichael_hasson OS Professional Posts: 14 ✭✭
    Hi Pete
    It sounds like you may be working on them, but the current absence of weld symbols continues to be a serious limitation.
    Thanks again
  • bill_danielsbill_daniels Member Posts: 278 ✭✭✭
    Back to the OP's request.  I too would like to be able to realistically model a weld seam.  It would make presenting models to non engineering types easier since they often can't understand how parts are joined unless they see a recognizable weld seam.  I don't know of another CAD system that does this but it would be nice.
