Showing Welds in an assembly drawing
in Drawings
Is there a method of adding welds to an assembly drawing? It would be helpful once multiple parts are joined to have the ability to show this.
Thanks,
Thanks,
For a complete hack of a workaround to help get a drawing out the door, you could insert an image of the weld specification you want into the drawing. Sometimes in weldment drawings, there are not a great deal of variances in the welds specified - so it's possible this solution could be of help while you wait for the real solution in the meantime.
It sounds like you may be working on them, but the current absence of weld symbols continues to be a serious limitation.
Thanks again
