merging and hollowing two lofts
Hi All
I'm trying to model and 2-into-1 exhaust collector, and I've managed to create the shape I need, but I can't work out how to hollow it. My part is here. I've tried using shell, and in the top and bottom circles, creating an inner circle and then trying to loft-remove between them, but I'm failing. I need a constant wall thickness.
Can you help?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,927 image
    Hi Mark - you can only shell solids, not surfaces. Make a solid loft between the faces then try again?
    Neil (and Mark),
    I worked on a copy of it last night for about an hour and discovered early on that what Mark had was not solid. I changed the loft to make two solid lofts instead of surface lofts. For the life of me, I couldn't  make a shell that worked with 2 inputs and a single output. I tried splitting, boolean operations, and more that I don't currently recall. All to no avail. Maybe somebody more practiced with these types of shapes will have better luck than me.
    I was trying to maintain Mark's original shape. Yours is less "organic" than his original. Maybe the more "organic" shape Mark started with was causing he strange problems I was having when trying to merge the two lofts together.
    Maybe, in Mark's original model the lofts were actually twisted which doesn't help.
    That might explain why they neck down a bit in the middle when just lofting from one circle to another.
