Which Chromebook is best for Onshape?
I'm thinking about getting a Chromebook. For use at home, in the office and on the go.
I'm sure some Onshape users and/or staff members are already using Chromebooks...
Are there particular models I should look at?
Google's Chromebook Pixel looks very impressive, but sadly it is not sold in Europe.
Many other Chromebooks feel quite flimsy...
Do any of the Chromebooks have dedicated graphics? (May come in handy for Onshape/Workbench.)
Dries
Dries
1
lougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016
I own a Pixel that is almost 2 years old. It runs Onshape wonderfully and is my go to machine. I code on a Macbook pro but anytime I travel or go anywhere, the Pixel is my main machine and the only computer I own outright. I have been using Chromebooks since the idea of Chromium OS was announced. I built my first one on a eee701 and have had 4 others before the Pixel.
The biggest performance gain is with RAM (overall) and I would recommend looking at models that have 4GB. I know there is a new gen going to ship here soon (Pixel 2) and it will probably be pretty pricey. The leaders so far seem to be the ACER, ASUS and Toshiba with a recent entry from HP, doing a touch screen with the new T3 chip.
For me it is not yet my main machine but I am betting on the cloud and nearly everything I use (and evaluate to use) must run on a CB for me to take it seriously. I totally understand I might be on the extreme side of the spectrum but hopefully I have advanced the conversation. @John_F_Carr and I are continuing to make sure the builds are successful on Onshape and I am hoping soon we will support some touch event support on the web version. We have also purchased a few for our QA team so they are testing on them as well.Lou Gallo / PD/UX - Support - Community / Onshape, Inc.5
Dries
-how much does it weight? 3.5lbs
-16 gig ram
-fastest cpu 3.0gig i7 3.6gig turbo (always pay extra for the fastest cpu)
-nvidia graphics (retina resolution)
I've just searched for a high powered chromebook and can't find one. Seems like they cater to the <$500 market. I'm interested in them but don't see me buying one for work. I'll stick with a 13" macbook pro.
Please prove me wrong,
We don't have a number saying how visually pleasing the result is, and that's a reason we don't track test results.
Another reason is, in some circumstances we would rather change quality than speed in response to a change in the ratio (model complexity / graphics performance). My old, slow Chromebook has a smaller screen than my MacBook Pro. It doesn't need as much detail in the rendered model. What if in the next release we give my Chromebook a lower resolution model to render? Then it could keep up with my Mac. And any graphics advice we gave last month would be invalidated.
Would you even notice a small resolution difference? What our graphics developers consider horrible artifacts I hardly notice.
Here is the cool thing. Go to your local computer store and just log into your onshape account and try each model they have on display.... You can see for yourself how each performs.
My experience is that low cost to hi costs hardware, makes far less difference in Onshape than tradition installed applications.
Joe
Engineering Consulting Partner
Professor, Engineering Technology, Palomar College, San Marcos, CA
sowelldevon@gmail.com
760 809 9046
CarlsbadCAD Carlsbad,CA
I found that Chromebooks with real graphics worked best. I have an Acer CB5-311 with a Nvidia Tegra K1 chip in it and runs just fine ... $300. I tried ones with just an Intel graphics chip and OS didn't perform well.
As Joe suggested, if you have the option to try out some Chromebooks at a store, do it.
I've tried a number of graphics cards for OS and it does better with a good graphics card but nothing crazy. GeForce cards do well as do entry to mid-level Quadros (K600 or K2000, for example).
Dries
Dries
kyle above says " I use just 4gb ram on the ubuntu laptop running chrome browser and I am amazed at how quick onshape runs. It is a bit jerky especially with a large assembly but very workable."
is onshape CPU or GPU bound when it comes to delivering the actual graphics stream in the browser? IE is it better to look for a computer for a better graphics card or CPU to have the best possible performance? this assumes most or all other actions are done "in the cloud"....
thanks!
an interesting test would be to run onshape through a remote desktop where there is no graphics support, that would be a true test!
Quick search gave me ACNXMPRED008 13,3" Acer Chromebook with 4gb ram - I would like to have 8gb or more ram if the price is reasonable since I tend to collect a lot of tabs in my browser for reading later.. New Pixel is too expensive and I'm glad they don't ship to Finland (might be too tempting if they did)
ASUS CHROMEBOX-M004U perhaps?
http://www.amazon.com/Asus-CHROMEBOX-M004U-ASUS-Desktop/dp/B00IT1WJZQ
aicher@battleaxe.com
Tigard, OR
At first glance everything seems to run just fine. Opened Porsche model from public and gave it a spin, works like a charm.
Only thing bothering (if not having external mouse) is turning model with two fingers pressed over touchpad since two finger press acts like RMB.
Does anyone know any workaround to better use of the touchpad for turning model?
On my Chromebook, where the trackpad serves also as the mouse button, I do the initial two-finger, snakebite click (near the bottom LH corner of the pad) with an index finger from each hand. Then I can keep the pressure on with the left finger, which keeps the rotation feature "alive", so that I can use multiple swipes with the right finger until I have the desired orientation. Easier to do than to describe.
ON EDIT:
Even if you begin with a one-handed snakebite, you can change horses in midstream.
The one-handed snakebite has to be near the bottom, because the hinge is at the top of the trackpad, otherwise you cannot hold the 'button' down.
But once you are holding the pad down, which keeps rotation alive, it is no longer necessary to use two fingers. If you need more time or room at this point, you can bring in the left index finger to take over holding the button down, so your right finger can perform repeated swipes anywhere on the pad.
I'm sorry you're having trouble with graphics performance on your laptop. There are a lot of factors in play with these kinds of issues, so your best bet may be contacting our support team from the '?' menu in a part studio.
