How to make a pyramid
toxic_noodle832toxic_noodle832 Member Posts: 1
edited October 2016 in Community Support
Hello im trying to make a pyramid for something i'm making but cant figure out how?
    edited October 2016
    @toxic_noodle832, Kindly refer below video which will be helpful to you for creating pyramid as suggested by @NeilCooke
    You can also extrude the triangle with a draft to get the same result. Just extend the extrude distance beyond the converging point.
    edited October 2016
    The method you use should depend on what your design intent is - or in other words - which is more important, the height or the angle?
  • brayden_mcdonaldbrayden_mcdonald Member Posts: 4 EDU
    If I wanted to use a pyramid as a roof of a rectangular prism of a house, how would I do so?
    pls help
  • steve_shubinsteve_shubin Member Posts: 1,116 ✭✭✭✭
    Are you looking for something like this ?
    yes kinda but im on a computer not a phone
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,958 PRO
    @brayden_mcdonald
    see @NeilCooke and @viru 's posts above
    Viru's animation is what you're doing, but just draw a square instead of a triangle, or any shape for that matter
