I want to gather solidworks parts into a part studio and continue working on them there. How?
Derived parts are cumbersome as you have to modify each part in a seperate browser tab, then create new versions etc: very messy. It seems by far the best way is to make an assembly of the parts in solidworks and pack&go it then import the lot. Is that true?
However, if I find later I've left some of the parts out of the P&G, I'm back to the derived parts mess.
bradley_sauln Moderator, Onshape Employees, Developers Posts: 373
You can directly edit parts derived into the same part studio. You do not have to go back and make edits to the originating part studio. The best part is, if you do make updates to the originating part, it will not automatically update the derived part if it is in a different document.
Let me know if this makes sense. I am happy to explain further and provide an example.5
Twitter: @bradleysauln
This will create a single part studio with all the parts in.
BOOM!
A while back @ilya_baran posted for feedback on an import updating system, this may be the solution to your problem in the future. Not sure how this would look in the feature tree after you have done mods to the original import, maybe you would see a new feature 'updated import'. Looking forward to developments in this space. See post importing updating system here
With two decades of solidworks designs to reuse I can't bring it all in at once.
